1 - 5 of 5 Posts
Hello All,
I have been searching for pages on the web which may be could guide me to replace headlight bulbs on my 2001 Passat. The stealerships are quoting $100 for the driver's side.
Details:
2001 Passat, Driver's side Headlight bulb does not glow in high/low beam
Can you also recommend the bulbs I will need. I did check try searching on this awesome forum and reached this dead link
http://web.njit.edu/~rxp0835/b5/info.php
and hence requesting info again. Sorry if I may have missed other postings. It would be great if I could be redirected. Thanks in advance
Regards,
Kanna
Re: 2001 Passat Headlight buld replacement (darisgin)
Its a B5. Sorry for not mentioning it earlier
Re: 2001 Passat Headlight buld replacement (pskanna)
Do your have the 4 cylinder or the 6 ? It made a difference on mine. My V6 low beam was easy once I realized I could remove a plastic piece to access at least the low beam headlight. Pete
Re: 2001 Passat Headlight buld replacement (jayhawk)
Hi ,
I have the 4 cylinder. In my case as well only the low beam(on the driver side) does not work. The fog/high beam bulb is fine.
Thanks for your reply
1 - 5 of 5 Posts
