Year:2002
Make:Audi
Model:TT
Mileage:150000 M
Transmission:Manual
Engine:1.8t
Trim:ALMS
2002 Audi TT ALMS
Purchased from the original owner in Southern California (from a CA dealership), now in Phoenix, Arizona. Under carriage, wheel wells and engine bay are in excellent condition due to our climate. Fires up and drives like a brand new vehicle.
Interior
  • $5000 Interior
  • New oem door cards
  • New oem radio
  • New oem steering wheel
  • Custom car luggage
  • Billet shifter
  • Custom ceiling/visors
Exterior
  • Carbon fiber rear valance
  • Carbon fiber rear wing
  • Carbon fiber mirror caps
  • Custom grill
Suspension/brakes
  • KW coilovers
  • Adjustable rear control arms
  • Front x-drilled rotors newish pads
  • Rear x-drilled rotors newish pads
  • H&R sway bars
  • Custom made Forgestar F14's made specifically for this exact vehicle out of California.
Engine
  • GIAC Flash
  • 007 DV
  • Cold air intake
  • Full Borla twin tip exhaust
PLEASE NOTE: The Forgestars are currently out being repowdercoated, they will be close to the color noted below. They were in 100% mint flawless show condition, the shop mounting fresh tires ~scuffed up the perfect current finish, so are being redone.
Cons
  • ~4" strip of clear coat is peeling up, can easily be sanding away/blended. That same rear panel has some minor scuffs, I was just going to have the whole section resprayed.
  • Drivers mirror switch needs replacement ($56 shipped).
  • The new passenger door has a little bit of delamination where the oem leather has lifted off the door card, simply needs to be glued back down due to Arizona dry conditions.
  • Both front axles were replaced with oem units, one boot on one axle just tore. Axle is fine, just needs a new boot probably from Arizona dry rot.
  • Standard half working lcd pixels
  • Belt tensor pulley is slightly noisy at idle (always been).
  • 50 state compliance emissions
  • Cold AC
  • Can be driven anywhere
  • Lots of attention
It's close to being a show car, honestly who ever gets it should only consider it if you have a garage...you can daily it but probably deserves better then that (take out on weekends instead).
$10k firm, no trades, located in Phoenix, Arizona - Blake 602-487-383eight
