Alrighty so been trouble shooting this for too long. One day got home shut it off wouldn't start after. Fuel pump was bad replaced it with a new fuel pump and changed filter, still would not start, have spark, getting 12v to fuel injectors, timing is correct, got a code for fuel relay replaced that, still not starting, shot carb cleaner in and tried to start, it started on carb cleaner, no vacuum leaks, no codes, drained all gas out of fuel tank put in 91 octane from shell still no starting, fuel injectors are spraying. I am at a loss at this point any advice would be greatly appreciated.
