Interesting, my 2001 1.8t Gti wouldn't start without clutch pedal depressed, as far as I can remember.My New Beetle starts without pressing the clutch pedal. I assume that is how they came from the factory
Mine is a 2000 2.0. Maybe the pedal sensor is stuck at depressed. In any case I can start the engine without pressing the clutch pedal.Hmm, not the case on my former 00' GLX and current 02' Turbo S. What year is your New Beetle?
You can also lift one of the front wheels, wind a rope around the wheel and pull it.I can't tell about pop starting it because I live on a hill and if it doesn't work it'll be down the hill.
have you checked your main positive battery wire going down to the starter? they like to brake off and corrode around the clamp, it could look good, but as soon as you tug on the wire it breaks off.Brand new battery. Still nothing.
Early models didn't have the switch (I think. my VR6 2000 didn't have one either)My New Beetle starts without pressing the clutch pedal. I assume that is how they came from the factory
I have my son's friend's 1999.5 Vr6 GTI in my backyard and it has the switch.have you checked your main positive battery wire going down to the starter? they like to brake off and corrode around the clamp, it could look good, but as soon as you tug on the wire it breaks off.
Remove/release tension on your accessory belt, I have seen people scrap their car because A/C compressor seized up and the motor won't turn over (does a click and that's it)
The starter solenoid makes the gear kick out and engage the flywheel. which in turn turns the motor over. Just because your new starter turns over that doesn't mean the new starter solenoid on the new starter is good. If you would listen to people trying to help and get the new starter tested we could move on from there.Yeah I don't think that's the issue, friend. I turn the key, nothing happens.
I jump 12v from the battery to the starter, it spins.
Changning to a different brand starter would not fix the issue. What I don't understand is that when I turn the key, I get 12v to the plug that snaps into the starter. Makes no sense.
