1 - 7 of 7 Posts
Scanned with VAG-COM and got 2 faults
1 Fault Found:
000291 - Throttle Position Sensor (G69): Signal too High
P0123 - 001 - Upper Limit Exceeded - MIL ON
Readiness: 0000 0000
and
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
It has done it a few times now. EPC light and traction control light both come on and the traction control button lights up OFF. Engine seems to be running on 50% power or less. Power seems closer to normal below 3k rpm but is very low on power above 3k rpm.
I park the car, it sits for a bit and then when I drive it again power is restored, shortly after the EPC light and traction control light turn off but CEL comes on. Shut the car off and drive again and eventually the CEL clears too and all is back to normal.
Any ideas?
· Vendor
There is a TSB for several throttle related faults on the 2.0T engines. It involves replacing the wiring and connector at the TB. I have a note here with the TSB number listed: http://wiki.ross-tech.com/wiki/index.php/17953/P1545/005445
Please post the complete Auto-Scan so I have enough detail to create a Wiki page for the fault you have.
VCDS Version: Release 908.2
Data version: 20100326
Saturday,12,June,2010,17:12:48:02337
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 52 55 56
VIN: WVWEV71K56W082135 Mileage: 108950km/67698miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 B HW: 1K0 907 115 B
Component: 2.0l R4/4V TFSI 0040
Revision: --H10--- Serial number: VWZ7Z0E2912321
Coding: 0403010A18070160
Shop #: WSC 03203 444 84374
1 Fault Found:
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0021122
Shop #: WSC 01279 785 00200
1 Fault Found:
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 DK
Component: Climatic PQ35 090 0505
Shop #: WSC 00000 000 00000
No fault code found.
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AA HW: 3C0 937 049 AA
Component: Bordnetz-SG H45 1402
Revision: 00H45000 Serial number: 00000002197646
Coding: B78F0F27000418000F1400000014000000197F0B5C0000
Shop #: WSC 03203 444 53622
Part No: 1K1 955 119 C
Component: Wischer VW350 013 0402
Coding: 00065493
Shop #: WSC 03203
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 P HW: 1K0 909 605 P
Component: 5L AIRBAG VW8R 032 6800
Revision: 02032000 Serial number: 0038FD0296T%
Coding: 0013644
Shop #: WSC 01269 785 00200
Part No: 1K0 959 339 D
Component: BF-Gewichtsens. 006 0006
Address 16: Steering wheel Labels: None
Part No SW: 1K0 953 549 AJ HW: 1K0 953 549 AJ
Component: J0527 034 0070
Coding: 0002022
Part No: XXXXXXXXXXX
Component: E0221 007 0050
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K6 920 972 E
Component: KOMBIINSTRUMENT VDD 4312
Coding: 0005407
Shop #: WSC 03207 444 59269
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800105A240065
Coding: 7D0F03400F0000
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0002
Revision: 00001000 Serial number: 1225223T11L302
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VDD 4312
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2389
Coding: 0001077
2 Faults Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.0 D06 1701
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AS HW: 1K0 959 433 AS
Component: 02 KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 929006885103083F0904058FB0080A0480A440
Shop #: WSC 01287 785 00200
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001077
Address 55: Xenon Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 D HW: 1K0 035 180 D
Component: Radio PM6 016 0017
Revision: 00016000 Serial number: VWZ5Z7E2025572
Coding: 0040400
Thanks.
Take a look if you dont have a coil that is popping out of its hole.
If not you could inspect them anyway and look for arcing. Clean your throttle body ( never hurts )
then perform the TSB.
Just got a call back from the dealer. They had recently performed the ignition coil TSB and one of them was loose.
You called it. Going to pick it up after work.
· Vendor
vw151,
Nice update! I'm working on the Wiki page and I can toss that note in there.
Bahltech,
Do you think the 5 faults included in the VW TSB (01-09-04 or 2018652 - wire harness extensions at TB) are all related to feedback through the coil circuits, or just that one, based on your real life experience?
Thanks,
Dana
1 - 7 of 7 Posts
