1 - 7 of 7 Posts
This hose is cracked on the other end. It goes behind and under throttle body. Electronic parking brake will not disengage. I'm guessing brake vacuum line. What hose is this? Part number will be helpful. Thank you .
White Automotive tire Hood Motor vehicle Wheel
07 Passat 3.6 4-mo
Parking brake is electronic. Hence why it's called "electronic parking brake". It runs on electrons not vacuum.
If it's not disengaging it's either the dash switch or caliper motor.
Replace the switch (stupid easy) or jack the car up and see which caliper is stuck. If it's both I'd venture a guess that it's the switch. If it's only one the motor is pooched.
If it's a bad motor unbolt the motor, wind the caliper (M8 spline I believe) and drive over to the parts store for a new one.
B6 4mo | fc3 Si
check my post here to look up parts and numbers
Discussion Starter · #7 ·
Thank you. That's it.
1 - 7 of 7 Posts
