1 - 9 of 9 Posts
2008 Audi A4 S-line Avant
-155k miles
-6 speed tiptronic
-Bi-Xenon headlights
-Heated and power seats
-Maintenance AND gas records
-Remote start
-Cam follower replaced (5/7/16 99,538)
-Timing belt replaced (5/7/16 99,538)
-Water pump replaced (5/7/16 99,538)
-Thermostat replaced (5/7/16 99,538)
-Serpentine belt replaced (5/7/16 99,538)
-Solowerks Coilovers (Rears are maxed out with collars still in, fronts have 3" left to go. Installed at 102k miles 6/26/16)
-Rear upper control arm bushings replaced (7/4/16 102,250)
-Valve cover gasket replaced (1/2/17 112,000)
-Front rotors and pads replaced (11/24/17 128,200)
-Rear coolant manifold replaced (12/30/17 129,600)
-Cam follower and chain tensioner pads checked during oil change. Checked out as good. (12/30/17 129,600)
-All new brake flex hoses all around (3/2/18)
-Front passenger CV shaft replaced (3/2/18)
-Air filter replaced (3/2/18)
-Cabin air filter replaced (3/2/18)
-Spark plugs replaced (3/2/18)
-Both front lower motor mounts replaced (3/2/18)
-Oil filter housing and gaskets replaced (3/11/18 132,900)
-Takata airbag replaced (6/19/18 133,349)
-Ignition coils and spark plugs replaced (5/15/19 146,261)
-New tires (Lionheart 235/40R18)
-New Battery with 2 year warranty (2/27/20)
-New rear license plate bracket and right light housing. Seat backs also fixed correctly (12/4/20)
-New rear brake rotors and pads (12/27/20 155,490)
-Can also come with a set of Rotiform LSR wheels (19x8.5 ET45 squared with General G-max RS tires with 5k miles on them)
Other
-Has the typical headlight dip error on the cluster from the front control arm level sensor for the headlights. The lights cycle and adjust to the correct height at start up everytime.
-Driver side front floor mat has seen better days
-Most likely could use an alignment at some time as the height has been adjusted numerous times since the last time it was done.
-I do have the front license plate bracket strip, was only removed in pictures to test fit a plate delete strip that was sent back for quality issues.
-Front has been raised 1/2" to level the car out front and rear since these pictures were taken.
-Leaves two small quarter sized drops of oil overnight directly under where the oil filter is. I have not gotten the car up in the air yet to check this out any further than that observation.(Can only be one of two things, either the oil cooler and filter housing gaskets or the housing itself. 130$ for all of these parts total at FCPeuro.com)
-Needs a new hood release lever as the guy who came for a test drive over the christmas weekend managed to snap it clean off. Cable is still intact and works to open the hood just fine.(12-18$ on ebay for a used oem one)
Located in Milwaukee, WI
PENDING SALE AS OF 1/9/21
I have more pictures of the car!! Thanks to this wonderful new site layout 20 is all I can post. Message me and I can send the rest if wanted.
20201204_160334 by Anthony Matysik, on Flickr
20201204_160343 by Anthony Matysik, on Flickr
20201204_160352 by Anthony Matysik, on Flickr
20201204_160359 by Anthony Matysik, on Flickr
20201204_160406 by Anthony Matysik, on Flickr
20201204_160415 by Anthony Matysik, on Flickr
20201204_160424 by Anthony Matysik, on Flickr
20201204_160432 by Anthony Matysik, on Flickr
20201204_160439 by Anthony Matysik, on Flickr
20201204_160512 by Anthony Matysik, on Flickr
20201204_160128 by Anthony Matysik, on Flickr
20201204_160141 by Anthony Matysik, on Flickr
20201204_160159 by Anthony Matysik, on Flickr
20201204_160214 by Anthony Matysik, on Flickr
20201204_160242 by Anthony Matysik, on Flickr
20201204_160236 by Anthony Matysik, on Flickr
20201204_160309 by Anthony Matysik, on Flickr
20201204_160258 by Anthony Matysik, on Flickr
20201204_160454 by Anthony Matysik, on Flickr
20201204_160613 by Anthony Matysik, on Flickr
Discussion Starter · #4 ·
Perfect time to get into a quattro before snow flies
Discussion Starter · #6 ·
Make your 2020 better with a Quattro purchase
Discussion Starter · #7 ·
fresh powder time
Discussion Starter · #8 ·
bumpage
Discussion Starter · #9 ·
4,300 for four rings
1 - 9 of 9 Posts
