My 2009 Beetle intermittently dies at idol. The only code that appears is a MAF Sensor Low Output code. I've tried 3 different sensors and still does it. The sensor seems to be reading correctly with the Ross-Tech VCDS at about 4-5 g/s flow at idol and rises proportionately with higher RPMs.
Any other thoughts on what could make the intermittent stall? It is like the engine just shuts down; but it usually will start right back up.
