1 - 1 of 1 Posts
Hello. My 2009 CC 3.6L VR6 4motion with 151,000 miles has started to display multiple voltage-related codes on items like cooling fan, airbags, Electronic Parking Brake and the Climatronic system. This happens even when the Central Electric I and II addresses are clean and present no codes. Is this a wiring issue? Are you aware of any simple way to replace the wiring on some of the specific components? For example, should I check the wiring harness for the cooling fan, or just replace the entire assembly? Thanks!
VCDS scan below:
Tuesday,09,March,2021,17:32:13:16365
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WVWGU73C59E513892 License Plate:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 36 37 42 44 46 47 4F
52 53 55 56 62 6C 72 77
VIN: WVWGU73C59E513892 Mileage: 243800km-151490miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
2E-Media Player 3 -- Status: Cannot be reached 1100
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 1010
72-Door, Rear Right -- Status: Malfunction 0010
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine (BLV) Labels: None
Part No SW: 03H 906 032 DN HW: 03H 906 032 AB
Component: P3.6-FSI-ULEV2 G 3056
Revision: 5GH04--- Serial number: VWZCZ000000000
Coding: 0000175
Shop #: WSC 05311 067 57207
VCID: 71BFD5D90DAAE453ADD-8024
No fault code found.
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09G-927-750.clb
Part No SW: 09G 927 750 HH HW: 09G 927 750 HH
Component: AQ 250 6F 1392
Revision: 00H76000 Serial number:
Coding: 0000840
Shop #: WSC 05311 000 00000
VCID: 7EA5FEE54CF48B2B20F-802A
1 Fault Found
01045 - Tiptronic Switch (F189)
008 - Implausible Signal
Address 03: ABS Brakes Labels: None
Part No SW: 3C0 614 109 P HW: 3C0 614 109 P
Component: J104 C4 440 V2 0011
Revision: --025--- Serial number: 00000785860289
Coding: 0000409
VCID: 2B0307B1EF06CE83D71-807E
1 Fault Found
01309 - Power Steering Control Module (J500)
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 207
Mileage: 243809 km
Time Indication: 0
Date: 2015.07.31
Time: 21:11:17
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 11.75 V
Bin. Bits: 00011111
Count: 221
Hex Value: 0x0000
Address 08: Auto HVAC (J255) Labels:* None
Part No SW: 5K0 907 044 N HW: 5K0 907 044 N
Component: Climatronic 120 0202
Revision: 00002001
Coding: 0000000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Climatronic A01001
ROD: EV_ClimaAutoBasis_VW46.rod
VCID: 363526C528C4836BB8F-8062
4 Faults Found
9479957 - Position Sensor for Indirect Ventilation Flap Motor
B10A7 15 [009] - Open or Short to Plus
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 22
Mileage: 237249 km
Date: 2021.03.09
Time: 10:34:56
9481748 - High Pressure Sensor
B10AE 14 [008] - Open or Short to Ground
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 236
Mileage: 243263 km
Date: 2021.03.09
Time: 18:18:18
9479443 - Control Circuit for Front Right Seat Heater
B10A5 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 226
Mileage: 242219 km
Date: 2021.03.09
Time: 12:47:43
9479699 - Control Circuit for Front Left Seat Heater
B10A6 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 17
Reset counter: 236
Mileage: 241947 km
Date: 2021.03.09
Time: 16:49:20
Address 09: Cent. Elect. Labels: None
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000008572183
Coding: F3E68F8B40041A0047970F0017000000002AFB4764400165170000000000
Shop #: WSC 97000 444 54535
VCID: 33331FD1373696439F1-8066
Subsystem 1 - Part No: 3C8 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 310508 022 0602
Coding: 00046997
Shop #: WSC 97000
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 040708 054 0402
Coding: 00209133
Shop #: WSC 97000
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 3C8 919 475 HW: 3C8 919 475
Component: PARKHILFE 8K H07 0007
Revision: -------- Serial number: 97530818701518
Coding: 300101
VCID: 71BFD5D901AAE453ADD-8024
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 HW: 5N0 959 655
Component: J234__314 VW10 HI 1815
Revision: 19013000 Serial number: 0039BPDP3YRL
Coding: 0012596
VCID: 7AADF2F550DCA70B1C7-802E
Subsystem 1 - Part No: 3C8 959 339
Component: BF-Gewichtsens. 001 0003
Subsystem 2 - Serial number: 0000000000135Q
Subsystem 3 - Serial number: 0017.05.080000100000650057ÿ†63
Subsystem 4 - Serial number: 650057ÿ†6333FTS649181598 ÿ†63
Subsystem 5 - Serial number: 81598 ÿ†6343FTS659771598 ÿ†63
Subsystem 6 - Serial number: 71598 ÿ†6353ETS6C281UVNH ÿ†63
Subsystem 7 - Serial number: 1UVNH ÿ†6363ETS64F23UVNP ÿ†63
Subsystem 8 - Serial number: 3UVNP ÿ†6374CTS6115OSVNH ÿ†63
Subsystem 9 - Serial number: OSVNH ÿ†6384CTS69N7OSVNP ÿ
Subsystem 10 - Serial number: OSVNP ÿ
2 Faults Found
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 195
Mileage: 222235 km
Time Indication: 0
Date: 2015.02.27
Time: 15:18:24
03551 - Functional Restriction of Seat Occupied Recognition
000 - - - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 196
Mileage: 222235 km
Time Indication: 0
Date: 2015.02.27
Time: 15:18:24
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AJ HW: 3C0 953 549 AJ
Component: J0527 0025
Revision: 00030000 Serial number: 3C5953507CN
Coding: 0001811
Shop #: WSC 97000 444 78384
VCID: 74B1DCCD72B8D17B46B-8020
Subsystem 1 - Part No: 3C8 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H2ÿ 0021
Coding: 00000227
Shop #: WSC 00000
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI1
Part No SW: 3C8 920 970 B HW: 3C8 920 970 B
Component: KOMBI H19 0023
Serial number: 00000000000000
Coding: 240F00
Shop #: WSC 05311 115 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod
VCID: 2B0307B1E386CE83D71-807E
Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 J HW: 3C0 907 951
Component: J533__Gateway H13 0152
Revision: H13 Serial number: 2200R08704818D
Coding: FDA3FF06504613009002
Shop #: WSC 00001 666 37046
VCID: 2809F8BDFEF0E59B3A3-807C
5 Faults Found
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 211
Mileage: 217645 km
Time Indication: 0
Date: 2014.12.02
Time: 22:23:15
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 240801 km
Time Indication: 0
Date: 2015.07.31
Time: 15:59:60
01304 - Radio
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 247
Mileage: 240801 km
Time Indication: 0
Date: 2015.07.31
Time: 15:59:60
03272 - Control Module for Audio Interface
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 116
Mileage: 240801 km
Time Indication: 0
Date: 2015.07.31
Time: 15:59:60
02873 - Control Module for Back-Up Camera (J772)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 244
Mileage: 242381 km
Time Indication: 0
Date: 2015.07.31
Time: 13:49:05
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BS 907 554 A HW: 0BS 907 554 A
Component: Haldex 4Motion 4013
Coding: 0000005
VCID: 44D14C0D629821FB36B-8010
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 AK HW: 3C0 959 433 AK
Component: IMMO 051 0383
Revision: 00051000 Serial number: VWZCZ000000000
Shop #: WSC 02402 444 103405
VCID: 73B3DFD177B6D6435F1-8026
Subsystem 1 - Part No: 3C0 905 861 J
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 2E: Media Player 3
Cannot be reached
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C8 959 760 HW: 3C8 959 760
Component: J810 0801
Revision: 00002000 Serial number: 00000000000000
Coding: 0000001
VCID: 72BDDAD508ACDF4B547-8026
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1531
Revision: 71009005 Serial number: 00000016388620
Coding: 0001463
VCID: 40D9401D76803DDB123-8014
1 Fault Found
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 6
Fault Frequency: 2
Reset counter: 246
Mileage: 242568 km
Time Indication: 0
Address 44: Steering Assist Labels: None
Part No SW: 5N1 909 144 J HW: 5N1 909 148 F
Component: J500__APA-BS KL.0 0502
Revision: 1AH02254 Serial number: 00083520028902
Coding: 0000258
VCID: 392F2DF9155A6C1355D-806C
1 Fault Found
02546 - Steering Limit Stop
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 207
Time Indication: 0
Freeze Frame:
Term 15 On
RPM: 0 /min
Speed: 0.0 km/h
(no units): 4.0
Voltage: 11.90 V
Address 46: Central Conv. Labels: Redir Fail!
Component: KSG PQ46 RDK 051 0221
Coding: 13910F8001864E763600141FF08A8F0E087801
Shop #: WSC 97000 444 88009
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 47: Sound System Labels: 3C0-035-456.clb
Part No SW: 3C8 035 456 C HW: 3C8 035 456 C
Component: DSP 10 Kanal 0070
Revision: 00H05001 Serial number: 75805000395903
Address 4F: Centr. Electr. II (J533_) Labels:. 1K0-907-532.clb
Part No SW: 1K0 907 532 HW: 3C0 907 951
Revision: -------- Serial number: 2200R08704818D
Coding: 01030100
Shop #: WSC 00000 000 1979136
VCID: 6695B685386433EBC8F-8032
Subsystem 1 - Part No SW: 6R0 959 591 HW: 6R0 959 591
Component: J245 H04 0052
Serial number: 826500014160
Coding: 000006
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1531
Revision: 71009005 Serial number: 00000580488622
Coding: 0001462
VCID: 41DF45197D8A34D31DD-8014
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
Component: J540 EPB3 VW-10498 0003
Revision: 009 Serial number: 00000000144035
Coding: 0000057
Shop #: WSC 03909 444 122436
2 Faults Found
02432 - Supply Voltage for Left Parking Brake Motor (V282)
011 - Open Circuit - MIL ON
Freeze Frame:
Fault Status: 11101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 207
Mileage: 243809 km
Time Indication: 0
Date: 2015.07.31
Time: 21:11:30
Freeze Frame:
Voltage: 11.80 V
Count: 30
Speed: 0.0 km/h
Hex Value: 0x1270
Hex Value: 0x0001
Hex Value: 0x0101
01087 - Basic Setting Not Performed
000 - - - MIL ON
Freeze Frame:
Fault Status: 11110000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 206
Mileage: 243807 km
Time Indication: 0
Date: 2015.07.31
Time: 14:28:22
Freeze Frame:
Voltage: 13.30 V
Count: 43
Speed: 0.0 km/h
Hex Value: 0x1250
Hex Value: 0x0001
Hex Value: 0x0101
Address 55: Headlight Range Labels: None
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0133
Revision: 00H04000 Serial number:
Coding: 3536008
VCID: 34311CCD3238917B86B-8060
Subsystem 1 - Part No: 1K0 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0002
Coding: 00000053
Subsystem 2 - Part No: 1K0 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0002
Coding: 00000053
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 3C8 959 703 B HW: 1K0 959 795 Q
Component: J388 TUER-SG HL 0309
Revision: 43004101 Serial number: 00000000480429
Coding: 0001168
VCID: 313F15D9CD2AA453EDD-8064
1 Fault Found
00934 - Electric Window Motor; Rear Left (V26)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 246
Mileage: 243807 km
Time Indication: 0
Address 6C: Back-up Cam. Labels: Redir Fail!
Part No SW: 3C8 907 441 HW: 3C8 907 441
Component: J772__Rearview 0022
Revision: 00H06000 Serial number: 525PA8-J820303
Coding: 0120008
Shop #: WSC 05310 666 43180
VCID: 678BBB81336E2AE3F39-8032
1 Fault Found
02203 - Audio / Video Input 1
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 4
Fault Frequency: 11
Reset counter: 247
Mileage: 241960 km
Time Indication: 0
Date: 2015.07.31
Time: 17:48:49
Freeze Frame:
Term 15 On
Reverse ON
Count: 3
Address 72: Door, Rear Right Labels: Redir Fail!
Part No SW: 3C8 959 704 B HW: 1K0 959 794 Q
Component: J388 TUER-SG HR 0309
Revision: 43004101 Serial number: 00000000500179
Coding: 0001168
VCID: 323D1AD5C82C9F4B947-8066
1 Fault Found
00935 - Electric Window Motor; Rear Right (V27)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 246
Mileage: 243807 km
Time Indication: 0
Address 77: Telephone
Cannot be reached
End----(Elapsed Time: 02:57, VBatt start/end: 11.6V/11.5V. VIgn 11.5V)-----
1 - 1 of 1 Posts
