1 - 20 of 29 Posts
Discussion Starter #1
I was attempting to add door warning lights to my car, but it appears that I cannot modify my door controllers because they do not have a .clb file for them. I've attached my auto scan below, what other information is needed so I can access these controllers?
Saturday,11,September,2010,14:04:13:10807
VCDS Version: Release 10.6.1
Data version: 20100831
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 65 72 77
VIN: xxxxxxxxxxxxxxxxxx
01-Engine -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 CL HW: 03L 906 022 TS
Component: R4 2,0L EDC G000SG 6935
Revision: 12H03--- Serial number:
Coding: 0050072
Shop #: WSC 00066 000 00000
VCID: 77D339217FBF
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 114B600C492900FF881106EA92220042300000
VCID: 78D13A1D72A1
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
Shop #: WSC 00066 000 00146
ASAM Dataset: EV_Climatic A01005
ROD: EV_Climatic_VW36.rod
VCID: 75CF332965B3
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 085 G HW: 5K0 937 085 G
Component: BCM PQ35 B++ 111 0129
Revision: BI111001
Coding: 2F380E3A902F3EC480080081640000C405400086535D8560648020000000
VCID: 3753F9213F3F
Part No: 1K1 955 119 F
Component: Wischer 23031 21 0512
Coding: 009795
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4D0AKHD6
Coding: 00003044
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360_VW36.rod
VCID: 3957FF19092B
Seat occupied recognition:
Part No SW: 1KM 959 339 HW: 1KM 959 339
Component: BF-Gewichtss. 007 0001
Serial number: ---0000R--000546CM00
Driver's Airbag Crash Sensor:
Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME7E51124DZZZ/
Passenger Side Airbag Crash Sensor:
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME4E03664EZZZ2
Driver's Rear Airbag Crash Sensor:
Component: S.Sens.Fahr.H --- ----
Serial number: 3511HSME7541751FZZZQ
Passenger's Rear Airbag Crash Sensor:
Component: S.Sens.Beif.H --- ----
Serial number: 3521HSME675A1520ZZZI
Driver's Front Airbag Crash Sensor:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME56441B20ZZZ9
Passenger's Front Airbag Crash Sensor:
Component: F.Sens.Beif --- ----
Serial number: 35627SME46211420ZZZ/
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 056 0111
Coding: 0000532
VCID: 78D13A1D72A1
Part No: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Coding: 00000130
Shop #: WSC 00000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K0 920 970 Q HW: 5K0 920 970 Q
Component: KOMBI H13 0112
Revision: X0013004 Serial number:
Coding: 270F00
ASAM Dataset: EV_KombiUDSMM9RM10 A04102
ROD: EV_KombiUDSMM9RM10.rod
VCID: 3C59E60D0619
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 020310F1001480
Coding: E9807F07001612002002
VCID: 69F76F59390B
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223T7B9A04
Coding: 0000002
VCID: FEDDAC05D085
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 920 970 Q
Component: IMMO H13 0112
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ImmoUDSMM9RM10 A01102
ROD: EV_ImmoUDSMM9RM10.rod
VCID: EAF59055BC0D
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7667794498
Coding: 010000
VCID: 266D2465E895
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0000596162
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide_VW36.rod
VCID: 27732961EF9F
Slave Driver:
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388__TSG-HL 006 1401
Serial number: 00000004738489
Coding: 000490
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 3147C739D15B
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0000581670
Coding: 0004B4
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide_VW36.rod
VCID: 28712A5DE281
Slave Passenger:
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389__TSG-HR 006 1401
Serial number: 00000004736177
Coding: 000490
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H10 0035
Revision: -----20S Serial number: VWZ4Z7K3067362
Coding: 0100040004
VCID: 61E77779C13B
Address 65: Tire Pressure (J502) Labels: None
Component: RDK 111 0821
Coding: 018705
VCID: 3753F9213F3F
Address 77: Telephone (J738) Labels: None
Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
Component: Telefon H08 6900
Revision: 00008000 Serial number: 00000329339539
Coding: 412100
VCID: 2A75D055FC8D
End ---------------------------------------------------------------------
here is the info for my two front doors as it looks like you have just a two door:
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1525
Revision: 72009005 Serial number: 00000814298722
Coding: 0001269
VCID: 6FE6D8B007F6
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1525
Revision: 72009005 Serial number: 09051101122703
Coding: 0001268
VCID: 70E4DBCC1AC8
you just go to the controller for each door in VCDS and click on coding, in my case I added 000064 to each of the original coding and was able to enable door entry/warning lights.
Hope this helps, let me know if you have any additional questions
Discussion Starter #4
I think it comes up that way because the JSW's have virtual rear controllers. I think thats what the slave listing means but idk.
Vendor
Yes, you have the newer UDS window motors. I don't have any coding info on them at this time, but I'll look into this. Bump the thread up in a week or so if I don't reply before then.
You can't run control module maps on UDS modules, so the scan you provided is sufficient.
I have a 2010 Passat and I think it's the same set-up, with virtual controllers for the rear doors.
I also would like to retrofit the lights, so I'll stay tuned...:)
Vendor
Tweak3D,
Try this for the Driver side 0004F5 and ...
This on the Passenger side 0004F4
If you haven't installed the lights and wiring yet I would expect fault codes for each missing light.
Discussion Starter #9
Tweak3D,
I'll Ty this tonight or tomorrow. I haven't tried to install the lights yet as I wanted to confirm coding first. Now I also have to confirm the pinouts for this controller. Will it be possible to add the rear lights too? Or do they activate with the main controllers?
Tweak3D,
Just tried it on my 2010 Passat : Coding accepted and got the warning light error
Friday,17,September,2010,14:08:05:39975
VCDS Version: Release 10.6.1 (x64)
Address 42: Door Elect, Driver Labels: None
Control Module Part Number: 3C0 959 701 HW: 3C0 959 793
Component and/or Version: TUER-SG FT 002 0305
Software Coding: 0004F5
Work Shop Code: WSC 05311 115 00000
ASAM Dataset: EV_DCU42BroseDriveSide A03004 (VW46)
VCID: E5EFFC305513
1 Fault Found:
67584 - Warning Light for Front Door
B11F5 01 [009] - -
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 150
Mileage: 9113 km
Date: 2007.14.11
Time: 14:06:59
So it looks good. I will install the light next week and I'll keep you informed of the results
Thanks Dana :thumbup::thumbup:
Discussion Starter #12
Hey B6,
if you know the correct wiring locations on this controller, or find out before I do, please share here :)
Thanks,
Justin.
Justin,
Since we seem to have the same controller (according to the part numbers) the connections should be the same.
So, in the 2010 schematics, the light goes on T32a/18
That means pin 18 on a 32 pins connector
The ground is T32a/19
You will need repair wire 000 979 009 on T32a side and 000 979 019 on the light side.
Same on both sides.
Enjoy !
Discussion Starter #14
Justin,
Same on both sides.
Enjoy !
Perfect, Thanks, ill be doing this tomorrow for the front doors. Going to have to see whats going on with the rears and see if they need sperate coding in that slave module, or if it just emulates the front doors coding.
Vendor
Dana,
Would it be the same bit (6) for the slave rear controllers ?
I think so. When I tweak the example scan above I get: 0004D0
From original:
Slave Driver:
Coding: 000490
See if you can set door warning light faults in the rear doors with that.
Hi Dana,
After i played with some bit-settings, i got these faultcodes from the door modules. Every time i erase them, close and open the car again, they return.
Can you help me with erasing them completely??
Part No SW: 1T0 959 701 AG HW: 3C0 959 793 A
Component: TUER-SG FT 002 0311
Revision: 12101005 Serial number: 0000766437
Coding: 0214B0
Shop #: WSC 99999 123 12345
ROD: EV_DCU42BroseDriveSide_SE35.rod
VCID: 7CFCF52E4699
Slave Driver:
Part No SW: 1K0 959 703 AF HW: 1K0 959 795 S
Serial number: 00000004885300
Coding: 000490
3 Faults Found:
67074 - Motors for Central Locking
B122B 01 [009] - Lower Limit Exceeded
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 12
Mileage: 5070 km
Date: 2003.14.06
Time: 15:42:53
67330 - Switch for Central Locking
B122D 29 [008] - Lower Limit Exceeded
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 53
Mileage: 5070 km
Date: 2003.14.06
Time: 15:42:54
132610 - Motors for Rear Central Locking
B122C 01 [009] - Lower Limit Exceeded
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 12
Mileage: 5070 km
Date: 2003.14.06
Time: 15:42:53
Part No SW: 1T0 959 702 AC HW: 3C0 959 792 A
Component: TUER-SG BT 002 0311
Revision: 14101005 Serial number: 0000782981
Coding: 0214B0
ROD: EV_DCU52BrosePasseSide_SE35.rod
VCID: 79F2EC3A49AB
Slave Passenger:
Part No SW: 1K0 959 704 AF HW: 1K0 959 794 S
Serial number: 00000004887051
Coding: 000490
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 12
Mileage: 5070 km
Date: 2003.14.06
Time: 15:42:53
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 53
Mileage: 5070 km
Date: 2003.14.06
Time: 15:42:54
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 12
Mileage: 5070 km
Date: 2003.14.06
Time: 15:42:53
Thanks...
Vendor
Hi Dana,
Coding: 0214B0
Slave Driver:
Coding: 000490
3 Faults Found:
Coding: 0214B0
Slave Passenger:
Coding: 000490
3 Faults Found:
Thanks...
I was looking over your old scan and I see the master module coding is the same:
http://forums.vwvortex.com/showthre...ing-tweaks&p=66343309&viewfull=1#post66343309
Did the faults clear, or are all of those still in the modules? Did you change the coding of 09 while testing the doors?
Installed light on driver side door this evening and it works ! :thumbup::thumbup:
Byte 3, bit 6 enabled (0004F5)
BE CAREFUL when you wire the light. A diode is installed inside the housing so the polarity IS important, it's not just an incandescent light as I read on some DIY.
I installed light 1K0 947 411 A, so maybe earlier versions where just a bulb with no diode ?
At first, I got noting so I went back and had a look at my passenger side light that was waiting in the box. That's when I noticed the diode !
Great cheap retrofit, but these door clips are such a #*/$%""&";) I'll make sure to buy some spares before I try another door :laugh:
1 - 20 of 29 Posts
