I just purchased a 2010 VW Routan SEL 4.0L only 69k miles, Minivan came with no battery, installed new battery and starts up, engine is strong. The transmission's solenoids seem to be bad, it goes only into 1 - 2 gears, No 3 -4 or higher gears.
Driver's window has fallen down, would it be the Regulator or the window motor?
*** I understand these VW Routans are built on the Dodge/Chrysler platform, so they are 50+% Grand Caravans/Town & Country. ***
Need guidance on either to have the 62TE tranny repair with new Solenoid Pack, Valve Body and speed range sensors or go with a completely new/used 62TE Transmission from newer 2012-14 caravan.
Also are the 62TE Trannys from 2014 -2017 Caravan / Town & Country 3.8 or 3.6 Vans, the same as the 2010 62TE tranny?
Need Help with the different engines: 2008-2012 3.8 an 4.0 engine have 62TE tranny, is the 62TE tranny the same as the 2013 - 2017 3.6L engine Tranny (62TE) ???
Thank you in advance,:wave:
