1 - 7 of 7 Posts
Got a check engine light 3 weeks ago during one of the North American Polar Vortex cold snaps. The local temperatures had been down past -20C / -5F for most of the day before...... Was the adblue frozen?
I've reset the MIL, and it hasn't come back.... the car is under CPO warranty, but it's $50 to get it checked out, and a pain to leave it at the dealership for the day in the winter.....
Here's the scan....
Monday,17,February,2014,11:55:29:48545
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WA1LMCFE4BD000952 License Plate: ACJV357
Mileage: 83670km-51990mi Repair Order:
Chassis Type: FE (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 36 42 46 4C 4F 52 55 56 5F
62 69 6C 6D 6F 72 76
VIN: WA1LMCFE4BD000952 Mileage: 83670km/51990miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine (J623-CATA) Labels: 059-907-401-CAS2.clb
Part No SW: 4L2 910 401 HW: 4L0 907 401 D
Component: 3.0TDI EDC17 H16 0005
Revision: 54H16--- Serial number:
Coding: 2A2A4012253600050000
Shop #: WSC 48950 000 1048576
ASAM Dataset: EV_ECM30TDI0114L2910401 001005
ROD: EV_ECM30TDI0114L2910401.rod
VCID: E1C9F133F0F48B167BD-80B4
2 Faults Found:
9658 - Reductant Pressure Sensor Circuit
P204B 00 [237] - Implausible Signal
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 81646 km
Date: 2014.01.29
Time: 06:46:34
9642 - Reductant
P20E9 00 [096] - Pressure too High
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 81646 km
Date: 2014.01.29
Time: 06:46:34
Readiness: 1 1 0 0 0
Address 02: Auto Trans (J217) Labels: 0C8-927-750.clb
Part No SW: 0C8 927 750 S HW: 0C8 927 750 S
Component: AL1000 AISIN 001 1785
Serial number:
Coding: 001378
ASAM Dataset: EV_TCMAL991031 001001
ROD: EV_TCMAL991031.rod
VCID: 3C77E047B7D606FE88B-8069
No fault code found.
Address 03: ABS Brakes Labels: 4L0-910-517.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0099473
Shop #: WSC 31414 790 00001
VCID: 3467C8675786CEBE40B-8061
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 F
Component: FBSAUDIC6 ELV H05 0130
Revision: 00H05000 Serial number: 10602901606806
Coding: 0000131
VCID: 25412523EC5CA736C75-8070
Subsystem 1 - Part No: 4F0 910 132 J
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H01 0054
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AE
Component: KLIMA 4 ZONEN H13 0050
Revision: 00---021 Serial number: 00000000239902
Coding: 0000A036
VCID: 254125232C5CA736C75-8070
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 AC HW: 4F0 907 279 C
Component: ILM Fahrer H28 0360
Revision: 00000000 Serial number: 4F0907279
Coding: 0133114
VCID: 6ADB161F45C2484E2A7-803F
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H17 0100
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150059
Shop #: WSC 31414
Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
Part No SW: 4F0 035 110 A HW: 4F0 035 110
Component: CDC-MP3-Alp H44 0140
Revision: AA001001
VCID: 152115E3FC3C37B6575-8040
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 75 AIRBAG AUDI8RH43 0230
Revision: 07H43000 Serial number: 0038QD09GEHK
Coding: 0014133
VCID: 2B55D31B8AB89146111-807E
Subsystem 1 - Serial number: 6332QSME42531234%
Subsystem 2 - Serial number: 6342QSME6F65522CT
Subsystem 3 - Serial number: 6352QSME6D640F24R
Subsystem 4 - Serial number: 6362QSME5253392EL
Subsystem 5 - Serial number: 63734SME09621A0A$
Subsystem 6 - Serial number: 63834SME0B624A0E6
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 C
Component: J0527 0530
Revision: 00H06000 Serial number: 90026101610024
Coding: 0012242
VCID: 275D2F2B9650B526F59-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0100
Address 17: Instruments (J285) Labels: 4L0-920-xxx-17.clb
Part No SW: 4L0 920 900 Q HW: 4L0 920 900 Q
Component: KOMBIINSTR. H09 0211
Revision: 00000000 Serial number: FJW00DE6A
Coding: 8BD6640401000008020300
VCID: 3561F5639CFCD7B6775-8060
Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
Part No SW: 4F0 907 468 P HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0047
Revision: LB200032 Serial number: 3200L106200079
Coding: 00C303
VCID: 3C77E047BFD606FE88B-8069
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
2 Faults Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 25
Reset counter: 136
Mileage: 77838 km
Time Indication: 0
Date: 2013.12.26
Time: 15:34:00
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 50
Reset counter: 136
Mileage: 71838 km
Time Indication: 0
Date: 2013.10.25
Time: 13:13:00
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.60 V
Count: 18
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0064
Revision: AA000000 Serial number: 00001002003134
Coding: 00581300000011110000
VCID: 326BCE7F6D92C08E527-8067
Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0357
Revision: Serial number: 0004000066389
Coding: 011F07205E40440004
VCID: 489F8C97FB0E5A5E1C3-801D
Address 46: Central Conv. Labels: 4L0-910-289.lbl
Part No SW: 4L0 910 289 H HW: 4L0 907 289 H
Component: Komfortgeraet H10 0110
Revision: 0110 --- Serial number: 01314791810000
Coding: 3569693
VCID: 3561F5635CFCD7B6775-8060
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H03 0110
Revision: 00000276 Serial number: 00002760020307
Coding: 0758473
VCID: 23453B3BE2685906A91-8076
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H13 0100
Revision: Serial number: 00000000069255
Coding: 0012001
VCID: DEB3CACF098AB4EE46F-808B
Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0357
Revision: Serial number: 0004000065598
VCID: 479D8FABF6105526159-8012
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000007
VCID: 3F8D974B6EC01DE6AD9-806A
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 082 HW: 4G0 035 082
Component: Radio U SIRIU H51 0052
Revision: AB001007 Serial number: 471F20A7509939
Coding: 020007020100000000
VCID: DDB1CDC3C48CAFF65F5-8088
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 4L0 035 648 A HW: 4L0 035 648
Component: B-B-NA H48 0117
Revision: -------- Serial number: 325FZ0A7510579
Coding: 010000060004E3EF41002305EF6300030200
VCID: 2B55D31B4AB89146111-807E
Subsystem 1 - Part No SW: 4L0 919 604 HW: 4L0 919 604
Component: DU6 Basic H43 0306
Subsystem 2 - Part No SW: 4L0 910 609 HW: 4L0 919 611
Component: E0380 Bedient H05 0060
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0357
Revision: Serial number: 0004000071598
Coding: 010E07204040230004
VCID: 468382AFF11A4C2EEEF-8013
Address 69: Trailer (J345) Labels: 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H08 0070
Revision: 2A001001 Serial number: 00000131769802
Coding: 0200000000000000
VCID: 3169C1736894FB962BD-8064
2 Faults Found:
02579 - Trailer; Left Brake Lamps (M65)
010 - Open or Short to Plus - MIL ON
Freeze Frame:
Fault Status: 11101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 67
Time Indication: 0
02580 - Trailer; Right Brake Lamps (M66)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 67
Time Indication: 0
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H04--- Serial number: 525PA8-J0640OU
Coding: 1021101
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Component: ValeoHeckdeckel H55 0500
Revision: --H55001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: ECD79007CF36D67ED8B-80B9
Subsystem 1 - Part No: 4L0 910 946
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD24.06.10--H55001001B0331ÿ
Subsystem 4 - Serial number: 1B0331ÿ
Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0070
Revision: AAH05061 Serial number: 105747475-----
Coding: 0003595
VCID: 2643222F915AAC2ECEF-8073
Subsystem 1 - Part No: 4L0 910 591 A
Component: J_245_EE16_SKB10H10 0220
Subsystem 2 - Part No: 4L0 910 591 A
Component: J_394_EE16_SKB10H10 0220
Subsystem 3 - Part No: 4L0 910 591 A
Component: J_392_EE16_SKB10H10 0220
Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
Component: TSG HR H11 0357
Revision: Serial number: 0004000071615
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4L0 910 283 C HW: 4L0 919 283 C
Component: Parkhilfe 8-Kan H02 0500
Revision: 00H02000 Serial number: 12691016500139
Coding: 0231266
VCID: 2A5BD61F8542884EEA7-807F
End ---------------------------------------------------------------------
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 81646 km
Date: 2014.01.29
Time: 06:46:34
9642 - Reductant
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 81646 km
Date: 2014.01.29
Time: 06:46:34
Serial number:
Coding: 001378
Revision: 00H02001
Coding: 0099473
Coding: 0000131
Coding: 0000A036
Coding: 0133114
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
Revision: AA001001
Coding: 0014133
Coding: 0012242
Coding: 00C303
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 25
Reset counter: 136
Mileage: 77838 km
Time Indication: 0
Date: 2013.12.26
Time: 15:34:00
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 51
Reset counter: 96
Mileage: 71838 km
Time Indication: 0
Date: 2013.10.25
Time: 13:13:00
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.60 V
Count: 18
Coding: 3569693
Coding: 0758473
Coding: 0012001
Coding: 0000007
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 67
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 67
Time Indication: 0
Coding: 1021101
Coding: 0003595
Coding: 0231266
It came back. Going in to the dealer for cpo claim, along with power steering
Sent from my SGH-I747M using Tapatalk
Failed sensor in adblue pump. $1000 part covered under CPO Warranty
Wow, I know it's under the CPO warranty but that price is like armed robbery. If I go into a convenience store with a gun and get caught there is a mandatory minimum sentence. If Audi does it, it's just business. They must use gold leaf to coat the assembly.
1 - 7 of 7 Posts
