1 - 2 of 2 Posts
Hi everyone.
I have a problem with retofitting the OEM bi xenon headlight to my Euro passat b7 2011. I have everything working except high beams. The problem is that in the electrical scheme i found in ELSAwin main beam should be connected from BCM to pins 11 on headlights. I did that and high beams didnt work even though i got the 12V on pin 11 when I turned on high beams. I investigated a bit and found out that my headlights don`t have pin 11.
I only have this:
pin 1, 2 - CAN HI and LOW
pin 4 - 12v from fuse
pin 6 - low beam
pin 5,7 - ground
pin 9 - marker
pin 10 and 12 - led drl
So now what. Please help me.
Rene
1 - 2 of 2 Posts
