2012 Audi TT RS 2.5 TFSI Quattro MT6 Coupe
Mileage: 37,819
Technical Specifications
Transverse mounted 2.7 liter DOHC turbocharged 20 valve inline 5 cylinder with TSFI direct ignition; 034 Motorsport carbon fiber cold air intake system; APR cast downpipe exhaust system; APR stage II ECU flash (modifications total 431 HP & 441 ft-lbs of torque on 93 octane); titanium sport exhaust Amsoil 20W50 series 2000 racing oil.
Transmission:
Quattro all-wheel drive; 6 speed manual transmission; Royal Purple synthetic transmission fluid.
Suspension:
MacPherson strut front suspension with 3-point lower control arm and stock sway bar; four* link rear suspension; 034 Motorsport adjustable 22.25 mm solid rear sway bar; adaptive magnetorheological damping; electronic stability control (ESC); anti-slip regulation (ASR).
Wheels/Tires:
Audi 19x8S' 5 arm rotor-designed titanium wheels with Michelin Pilot Super Sport 255/35 ZR 19 tires (summer)); BBS l 8x8" SR wheels with Yokohama W Drive 245/40 R 18 tires (winter): locking lug nuts & red Audi valve stem caps.
Brakes:
Dual circuit system with ABS anti-lock; disc brakes (front) = 370 mm, perforated & ventilated rotors with high gloss red painted 4-piston calipers; stainless steel braided brake lines; disc brakes (rear) 034 Motorsport rear brake rotor upgrade kit fitting 2-piece 335 mm Audi RS6 OEM rotors cross-drilled to match front rotors with stock calipers painted red; stainless steel braided brake lines; Motul RBF-600 racing brake fluid.
Bodywork/Lighting:
Panther black crystal effect paint; LSD/LLTek Motorsport vertical door conversion kit; front & rear spoilers painted aluminum matte to match mirrors & gas cap; titanium grille; xenon plus headlights with LED daytime running lights; 3M Roadblock paint protection system; tinted windows; Audi Sport rear license plate bracket; MY TTRS vanity license plates.
Interior:
Black leather sport seats; grey alcantara panels in the seats and doors replaced with red alcantara; Schroth 4-point shoulder harness & pads for driver's side; P3 vent gauge with analog boost sensor installed in left OEM air vent; custom embroidered dash mat; Halitron fire extinguisher mounted in front of passenger seat; coco floor mats; sound deadening materials throughout.
In-car Entertainment:
Bose 140 watt 9-speaker sound system: Alpine PLT-5 powered subwoofer installed behind rear seats; Sirius satellite radio; portable battery-operated Escort Passport radar/laser detector; Hella l 18db air horns.
Link to pictures will be attached
Asking $69,999 or best offer
Mileage: 37,819
Engine:Transverse mounted 2.7 liter DOHC turbocharged 20 valve inline 5 cylinder with TSFI direct ignition; 034 Motorsport carbon fiber cold air intake system; APR cast downpipe exhaust system; APR stage II ECU flash (modifications total 431 HP & 441 ft-lbs of torque on 93 octane); titanium sport exhaust Amsoil 20W50 series 2000 racing oil.
Transmission:
Suspension:
Wheels/Tires:
Brakes:
Bodywork/Lighting:
Interior:
