Good choice on the flywheel, not sure which one in my car the shop ordered it for me. I assume your tuned so this setup why have no issue with the additional torque the tune brings.
Gave up on the UM tune.Did your clutch let go on the UM Stage 1 tune, or did you end up tuning for additional power before it gave up the ghost?
Interesting - how so? Was it too weak, or did it have some negative effect?Gave up on the UM tune.
I knew it was going to happen one day because of the additional torque with the tune. Lasted 1.5 years before it did give out.Interesting - how so? Was it too weak, or did it have some negative effect?
What tune ended up killing your clutch?
Yes, it was the way to go, as the synchros can be a bit sensitive, dual mass is apparently the best for the transYes I've stuck with the OEM flywheel lighter flywheel can cause issues if I remember correctly.
