1 - 3 of 3 Posts
So I upgraded the suspension to a bc racing br series kit, new ball joints sway bar links, struts. After 3 days of getting it back together the cv axles aren't engaging when put in gear. I never removed them just moved them aside while changing everything. Anybody got an idea of what the issue is hoping for an easy fix
I'm guessing one of your cv shafts came out of the transmission when it was moved aside. I mean, if this problem literally started the second you put the suspension together what else can it be?
Problem solved. The outer knuckle o. The driver side slid too far and came apart. Took the boot off got it back together, new clamp ring... good as new. As far as the suspension still playing with the adjustments but do not hesitate to check into the bc racing br series. This CC literally grabs the road like crazy now, sharp curves 65-70 mph no tire squeal😁
1 - 3 of 3 Posts
