1 - 5 of 5 Posts
We bought a used 2018 Jetta from an online dealer. I took it to the local VW dealership for an inspection and they found some oil leaking around the filter. I got it home, jacked it up to look around myself and noticed this "glue" on the frame by the right-front wheel. Would this be from the factory or a sign of some kind of repair?
Tire Wheel Automotive tire Hood Automotive lighting
Wheel Automotive tire Tire Automotive lighting Motor vehicle
Yes, that is sloppy factory seam sealer. When you zoom in close you can see that the ripple pattern is extremely uniform and tight - that wouldn’t be replicated by a shop. And only a robot would have lumped seam sealer on top of seam sealer in such an unproductive way.
1 - 5 of 5 Posts
