I will start by saying the car was smooth before I did what follows.
I bought new Moda MD27 18" rims, with centering rings, and Blizzak WS90's mounted and balanced. They were roadforce balanced to under 15 lbs. of roadforce. I'm nearly 100% confident it's not a balance issue as those are solid figures. I have my own machine in my garage, but this was done at a shop I am friends with.
I then added 10mm and 15mm ECS spacers to the front and rear, respectively. I also then bought extended CONNICAL bolts for the Moda Rims. I also have extended BALL SEAT bolts for the OEM rims.
From 60-70mph, the steering wheel shakes bad. So much you can see it move about 1" up and down. It's bad. The ECS spacers have the flange that extends off of the bore, so it centers on the rim/rings fine. I also added antiseize to the spacer. When I put the wheels on, I used the bolt you put in one hole to get the rim on. I tried to center everything and then put all the bolts in with a star pattern. I tightened them, but not fully. Lowered the car and torqued everything down in a star pattern.
What's at debate, to me? Do those MODA RD27 rims need conical or ball seat bolts? The vendor I bought them from, called their supplier, and they said BALL SEAT. I then called Tire Rack and they said CONICAL. Would mixing those up cause this? Could it be an issue with the spacers?
I appreciate some vibration at speed from poorly balanced/roadforced tires. I know that feeling. This is dramatic to see the wheel shake that much. It's shocking. Something is off. But, go back to my first comment. It was smooth with the OEM rims. So, it's NOT the car. I am 200% sure of that.
I see three potential areas of potential issue? Centering rings. Check, have them. Spacers? Not sure what could be wrong, but...? Ball seat vs. conical bolts. Could that do it? Also, how can I, for sure, understand what the MODARD27's take for this car? Short of swapping to the BALL SEAT bolts (the conical bolts are on now), I'm not sure what to do when my vendor says one thing and Tire Rack another.
Look forward to any guidance. Thanks!
