Status
Not open for further replies.
1 - 8 of 8 Posts
Re: 210 km/h... (Quik1.8T)
Looking at your signature, you have an upsolete chip, it is not normal, go back to where they install it and ask if the remove your "governor", speed limit. I've hit more than 210Km/h in mine.
130 mph is the set limit due to match the OEM H rated tires. You wouldn't want to exceed that by much without going to higher speed rated tires.
Dan
Re: 210 km/h... (CashmoneyUKR1)
all cars are electronically limited to 133, its a fact. where YOUR speedo reads maybe off from actual speed (acutally it's almost certain to be off a bit)
some chips dont remove the limiter.....UP I think is one...
Discussion Starter · #6 ·
I think the Giac chip remove the limiter, but like you said, i don't think the upsolute chip remove it.
But if i want to remove, what should i do?
quote:[HR][/HR]I think the Giac chip remove the limiter, but like you said, i don't think the upsolute chip remove it.
But if i want to remove, what should i do?[HR][/HR]​
APR or GIAC chip. And Z-rated tires, I wouldn't have the balls to do it on stockies.
quote:[HR][/HR]Yesterday i was at 137mph the limiter kicked in.[HR][/HR]​
And that gets this one the lock
Mike
1 - 8 of 8 Posts
Status
