So looking at new wheels for my 4motion AWD Atlas 2019. I’m going back and forth between 20, 21, or 22’s. I like the look of 22’s the most. I believe with 22’s you run 40 series tires. 21’s are 45 and 20’s are 50’s. Is there any negative effects to the drive train running 22’s over 20’s. Will the tire pressure sensors still work correctly with 21 or 22’s? I believe VW the only come stock with 18 or 20’s so wasn’t sure is there was any reason I shouldn’t go larger.
