Tonight I finally got my car in shape and running right after 3 days of chasing stupid problems that were totally my fault. Overall the 2871R is really nice for a daily driver, it spools about the same time as the KO4, but pulls like crazy at higher rpms
I used 630cc injectors in combination with Unitronics 630cc file. all I can say is WOW way to go Unitronic- As I said I fixed some bugs, (loose ground wire on the coilpacks, pcv leak under the intake mani. etc) And still have to adapt the TB after cleaning this weekend when I get vag com'd. Im still running the green spring in my forge DV - just got a blue tonight from a friend, and Im getting 25psi. Tonight it was raining and 50 degrees out, should I be getting 25psi? its almost scarry, but wow does it feel great, thanks again to everyone for the help, and input. Oh and Mike at Unitronic is the man. http://****************.com/smile/emthup.gif
