1 - 5 of 5 Posts
i may be putting the aba 2.0 motor i have in my A2. i was wondering if a 2H tranny would work (close ratio form an 83 GTi i think). i have the tranny from the 2.0, but it would be cool to have a close ratio one. thanks,
Re: 2H tranny in a 2.0? (vVWwDUB)
Yes it will work you just need a 8v small input shaft cluctch disc. Get a clutch from a 83 GTi will work.
Re: 2H tranny in a 2.0? (gtibunny8v)
Quote, originally posted by gtibunny8v »
what about the speed sensor? doesnt the mk3 speedo use i a sginal from a sensor in the tranny or something? is there a way to make it work? thanks
Quote, originally posted by vVWwDUB »
The spped sensor goes into the speedo cable hole on the 2H. The only difference might be is the reverse switch connector. Where your Mk3 will have a 2 pin connector and the 2H will have a 8 or 10 pin somewhere around there connector.
1 - 5 of 5 Posts
