1 - 15 of 15 Posts
So everynow and then.. when im shifting into 2nd.. it grinds.. and the sound is not a good one... anyway.. i have a 1998 jetta with 37k miles... what could be the problems for this? will it be under warranty?? thanks
Re: 2nd gear is grinding!=( (vwcruisn)
if you have a short shifter or anything take it out...but just tell them its grinding when i shift into second gear, and i think it could possibly be the second gear syncro, but wanted to see what you guys thought
i posted something about this awhile ago...
i thought it was just a fluke...
sometimes mine wont even hit 2nd in my 2.0 97 gti...
should i bring it in under warrantee?
they will prolly say it is my short shifter though
whoa...i must type slo...two replies by the time i hit up one...
[Modified by scarecro, 2:49 AM 11-28-2001]
Just tell them the problem your having and they will look at it and figure it out. They'll probly try to blow it off but be persistent and tell them its starting to be a big problem! And with your short shifter they will probly blame it on that so it will void your warranty and you have to pay. So be careful!
[Modified by Lukedub, 7:53 AM 11-28-2001]
There should be a FAQ on this.
1. You probably need a new 2nd gear synchro
2. You probably need to bleed and refill the clutch slave cylinder (bleed and refill the brakes while you're at it and have not changed the brake fluid ever)
3. You might need to get a new clutch slave cylinder
4. Don't know about the linkage shifters in the 8v cars... but you may need to have the linkage adjusted. Side to side movement, and front to back movement.
Last but not least... and I hope VW is listening.
5. Forget the warranty. It is not even worth the paper it is printed on. The grinding is one of many wonderful standard features courtesy of Volkswagen. The dealer will tell you "can't duplicate problem" and "everything is fine."
[Modified by Paul, 2:32 AM 11-28-2001]
Re: 2nd gear is grinding!=( (Paul)
2.0 famous for breaking the little golf ball in the linkage. will definetly make it sloppy shifting and grind second. Look in your bentley at the exploded diagram of the shift linkage. It is item 6 "relay lever". Easy to change and about $60 - 80 at the dealership. I've cahnged this on 3 of my friends cars. When the ball disappears it leaves a little plastic star looking piece or nothing bu a metal stud behind. Hope this helps.
Aloha
1 - 15 of 15 Posts
