Hi,
Hoping I could get some guidance on a couple sensor malfunction I'm getting. Here's what my Rosstech is pulling:
000912 - Camshaft Position Sensor (G301)
P0390 - 006 - Malfunction - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 4
Fault Frequency: 254
Reset counter: 40
Mileage: 190787 km
Time Indication: 0
Date: 2015.01.04
Time: 14:48:33
Freeze Frame:
RPM: 1408 /min
Mass Air / Rev.: 103.6 mg/str
Temperature: 97.5°C
Idle
Bin. Bits: 00000100
Speed: 0.0 km/h
000833 - Camshaft Position Sensor (G40)
P0341 - 006 - Implausible Signal - MIL ON
Freeze Frame:
Fault Priority: 4
Reset counter: 40
Mileage: 223954 km
Time Indication: 0
Date: 2015.12.27
Time: 13:06:44
Freeze Frame:
RPM: 1600 /min
Mass Air / Rev.: 272.5 mg/str
Temperature: 93.0°C
Part Throttle
Bin. Bits: 00000010
Speed: 47.0 km/h
000832 - Camshaft Position Sensor (G40)
P0340 - 006 - Malfunction - MIL ON
Freeze Frame:
Fault Priority: 4
Reset counter: 40
Mileage: 223997 km
Time Indication: 0
Date: 2015.12.29
Time: 11:28:53
Freeze Frame:
RPM: 2080 /min
Mass Air / Rev.: 174.4 mg/str
Temperature: 91.5°C
Part Throttle
Bin. Bits: 00000100
Speed: 103.0 km/h
001632 - Intake Manifold Tuning Valve Control Circuit (Bank 1)
P0660 - 009 - Elect. Malfunction
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Reset counter: 40
Mileage: 234097 km
Time Indication: 0
Date: 2016.04.21
Time: 17:38:01
Freeze Frame:
RPM: 864 /min
Mass Air / Rev.: 125.4 mg/str
Temperature: 97.5°C
Idle
Voltage: 11.83 V
Speed: 0.0 km/h
Do these values indicate which cam sensor (positions) are malfunctioning? I found a couple links on running resistance checks. Haven't even begun to check on the intake manifold tuning valve....
Freeze Frame:
Fault Priority: 4
Reset counter: 40
Mileage: 190787 km
Time Indication: 0
Date: 2015.01.04
Time: 14:48:33
Freeze Frame:
RPM: 1408 /min
Temperature: 97.5°C
Idle
Bin. Bits: 00000100
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 4
Reset counter: 40
Mileage: 223954 km
Time Indication: 0
Date: 2015.12.27
Time: 13:06:44
Freeze Frame:
RPM: 1600 /min
Temperature: 93.0°C
Part Throttle
Bin. Bits: 00000010
Speed: 47.0 km/h
Freeze Frame:
Fault Priority: 4
Reset counter: 40
Mileage: 223997 km
Time Indication: 0
Date: 2015.12.29
Time: 11:28:53
Freeze Frame:
RPM: 2080 /min
Temperature: 91.5°C
Part Throttle
Bin. Bits: 00000100
Speed: 103.0 km/h
Freeze Frame:
Fault Priority: 2
Reset counter: 40
Mileage: 234097 km
Time Indication: 0
Date: 2016.04.21
Time: 17:38:01
Freeze Frame:
RPM: 864 /min
Temperature: 97.5°C
Idle
Voltage: 11.83 V
Speed: 0.0 km/h
