1 - 11 of 11 Posts
Hello just looking for some input on custom header configuration.
So my flex pipes are leaking and I need to fix them.
The only info I found was it's not worth it for the money at least for the 12 valve. I've heard the 24 valve flows a lot better
My plan is to use 1.75" primaries or maybe a little bit bigger any thoughts? Ill have two 3 to 1 collectors and run dual pipes to the back because I have 4 total O2 sensors
If I make the primaries unequal length matching up to the unequal exhaust runners in the head would that equal out to equal length headers?
If I make equal length primaries would that become unequal because of the unequal exhaust runners in the head?
If I matched up the short exhaust runners in the head with the short primary tubes would it sound like a Subaru?
I do not have a Dyno but I like to keep performance in mind. I'm thinking matching up the short exhaust port runner and longer primary tube would be the best but short on short would probably sound pretty cool.
Any input will be considered thanks
Sent from my Moto Z (2) using Tapatalk
I've been looking for info on performance upgrades on my 08 TT 3.2l but when I usually ask I get crickets and most say that it's a useless endeavor trying to get power out of this motor. There's a guy on Facebook though that claims he got close to 300hp/tq to the wheels mainly with a custom dual exhaust set up and another post I found a while back where a guy claims to have gotten power by modifying the oe intake manifold and another guy who had a custom adapter made to fit the 3.6l intakenmanifold onto the 3.2l head. Most seem to think that the bottle neck is the intake manifold. Anyway I found longtube headers for the 03 - 08 Audi A3 Quattro and 07-09 Mkv R32 that should fit the Mk2 TT. I'm thinking that with a custom dual exhaust should yield some good hp/tq along with a good coldair intake and tune.
For street use ;), 268/264 cams, downpipes, HFC, 2 1/2" exhaust, United Motorsports ecu tune is good for 240 whp.
If that's not enough, spend the big money for the big turbo :whistle:!
Who sales those cams, Techtonics, Shrick? I haven't seen any downpipes/Hfc particular to the 8J 3.2l TT. It's already sounding like the hp to dollar ratio is horrible lol. There's gotta be a way to get atleast 260whp with bolt ons & tuning.
MK 5 downpipes, MK 4 HFC assembly (see below) mate right up, with the addition of less than 12" of pipe to the muffler end to connect to the catback system. The TT might not even need the extra length, but it's a simple add.
Naturally aspirated motors actually lose hp with larger tubes...
A group buy several years ago for Schricks went through a performance shop in B.C., but their website is gone. Have you checked with Four Seasons Tuning? Four Season Tuning Do a search on Schrick on the R32 forum: lots of info there.
240 whp is a step up from 190 whp, which is what the 24v VR6 puts down.
"There's gotta be a way to get atleast 260whp with bolt ons & tuning." There is...Turbo, but it requires deep pockets, and lots of maintenance. 🔧
Yeah looks like a 3.6l swap might be the way to go if I wanna stay NA. I just can't find enough specific, detailed information on doing it. My car is an 08 TT quattro 3.2l so I want to know if I only need the motor or motor trans, rear diff etc...
Well I finished port matching the oe headers. Next I'm going to heat treat them.👍
Here's some reading for the exhaust system:
There is a common misconception that engines need backpressure in order to run properly, generate low end torque, etc. That is simply untrue. Backpressure is a bad thing. Always. Take a look at a top fuel dragster...how much backpressure do you think those zoomie headers make? Very little, and those engines produce 6500 hp.
So, what is backpressure? Any fluid flowing through a pipe experiences drag on the walls of the pipe. This depends on a number of factors, including the diameter of the pipe, the smoothness of the inside of the pipe, the viscosity of the fluid, and the velocity of the fluid. This drag results in a pressure drop through the pipe. In order for the fluid to flow at all, the pressure on one end of the pipe must be higher than at the other. In an exhaust system, that pressure drop is what we refer to as backpressure. It's pretty obvious that the engine has to produce this pressure differential, so the less power it has to spend making pressure to push the exhaust out, the more power it can send to the wheels.
Given that exhaust pipes are pretty smooth, and that we can't change the viscosity (thickness) of the waste gas being forced through the pipes, we are left with basically 2 parameters we can have any control over: The pipe diameter and the gas velocity.
Unfortunately, the pipe diameter controls the gas velocity since the volume of gas is prescribed by the engine. So, we really only have one thing we can change. So, bigger pipes allow less pressure drop for a given volume of gas because the velocity is lower. The pressure drop (backpressure increase) is proportional the gas velocity squared, so if I double the gas velocity (by reducing the cross sectional area of the exhaust pipe by half) then I quadruple the pressure drop.
Well, there's an easy solution for that: Just make the exhaust pipe bigger. Bigger pipe, lower gas velocity, less pressure drop, so less backpressure. Wow, that was easy. After all, this is the way it's done for basically any type of commercial plumbing system. Need less pressure drop on a chilled water pipe or a natural gas line? Just make the pipe bigger.
But wait, there's a problem....Having a huge exhaust pipe has killed my low end torque!!! What's different? Oh, there's no backpressure!! Therefore backpressure makes torque!
Wrong.
An exhaust system is different than just about any other plumbing situation. How? Because the flow is pulsed, and this turns out to be a big deal. Every time a pulse of exhaust gas runs through the pipe, a strange thing happens: it as it passes, it has a little area of vacuum behind it. Just like a NASCAR stocker running around the track, the pulse generates a little bit of a vacuum behind it. In NASCAR, a driver can take advantage of another driver's vacuum by getting right behind him and driving in it. The wind resistance is drastically reduced. This is called drafting.
Well, how big the vacuum behind each pules is depends on the gas velocity. The higher the velocity, the bigger the vacuum the pulse has behind it.
Now, this means that I can "draft" the next pulse, just like in NASCAR. In NASCAR, it's called drafting, in an exhaust system, it's called scavenging. You've probably seen this term used when talking about headers, but the same concept applies in the pipe.
I get the maximum scavenging effect if the gas velocity is high, so the pipe needs to be small. By maximizing the scavenging effect, I help to pull pulses out of the combustion chamber, which means the engine doesn't have to work as hard to do that.
This has the most effect when there's a bunch of time between pulses...in other words, at low rpm. As the revs rise, the pulsed flow becomes more and more like constant flow, and the scavenging effect is diminished.
So, at low rpm I need a small pipe to maximize scavenging, and at high rpm I need a big pipe to minimize pressure drop. My exhaust pipe can only be one size, so it's a compromise. For a given engine, one pipe diameter will make the most overall power (i.e., have the largest area under the curve on a dyno chart).
So, the loss of torque has nothing to do with backpressure, and everything to do with gas velocity. So you need exhaust components that are not restricive (manifolds/headers, mufflers) and that are sized correctly for your application.
To further dispel the "backpressure is necessary" theory, try this if you want. If you have access to a vehicle with open headers, make a block off plate that will bolt to the collector. This plate should have only a 1" hole in it for the exhaust to flow through. That will give you PLENTY of backpressure, and zero scavenging. Then you can report back on how much low end power it has.
The one exception to sizing an exhaust is for turbo cars. Since the turbo is in the exaust stream, the gas flow spinning the impeller tends to come out of the turbo with the pulses greatly diminished. In this case, you can get away with running a larger pipe than on an equivalent HP N/A engine because you can't take as much advantage of the scavenging effect."
1 - 11 of 11 Posts
