A few updates.
1.) Cooling systems upgrades aren't leaking and operating as expected! I need to give it a stress test in the summer but so far so good.
2.) Malone tune was 10% off last weekend so the ECU is in transit to ECS for a flash. +10% power is nice but I'm really curious of the drivability differences, hopefully the rev hang is eliminated.
3.) Almost done with adapting the leak detection pump. The passat charcoal filter is probably 3x the size of the Corrado unit so I ditched it and will test a hybrid system with the Passat LDP and Corrado charcoal canister. Luckily the only room in the engine bay is next to the canister so everything fits pretty well!
The SLC has a basic fuel vapor system in the car from the factory. You have the gravity valve at the fuel filler neck and that routes through a nylon tube to the front of the car. What the LDP will do is pressurize the whole system from the N80 valve to the fuel tank and over time the ECU will check the pressure level and determine if there are any leaks in the system. So to adapt the Passat LDP to the Corrado system I am installing a T fitting in the fuel vapor line that is coming from the fuel tank so the LDP can pressurize the system.
For the below picture
Green arrow: output of the LDP
Red arrow: tube from the gravity valve/fuel tank
Yellow arrow: Tube to the charcoal filter
You can see a fatter tube coming out of the charcoal filter in the above picture, that routes to the N80 valve.
