1 - 20 of 75 Posts
Ok so I'm not putting together a step by step timing chain job thread because my projects usually don't follow the same steps as people who need to just fix their timing. Also doing the timing on a 3.6 is complicated job that requires you to separate the engine from the transmission. Some people may chose to pull the engine and transmission while others may prefer to just pull the transmission when touareg people might want to pull the engine. Its really a slippery slope and what needs to be done. Most importantly I want people to understand the process of re-timing the engine. where to get parts and the tools necessary.
The beauty of the 3.6 is that it has remained relatively unchanged since being introduced in 2006. I'm running a 2016 touareg engine on 2006 management.
List of vehicles this might pertain to:
Potential USA 3.6 VR6 Donors
Touareg 2007+
Passat 2006+
CC 2009-2017
Porsche Cayenne 2006+
Audi Q7 2007-2010
Atlas 2018+
Information Links
It should be noted that the Facebook page "VW 2.8 | 2.9 | 3.0 | 3.2 | 3.6 VR6 Performance Group" is useful...sometimes.
Link for looking up VW/Audi Part numbers up: http://volkswagen.7zap.com/en/rdw/ or http://7zap.com/en/
jddaigle's B6 3.6 & 4motion Resource Thread
Nater's Head Gasket R&R and DIY 3.6L BLV 2008 Passat https://forums.vwvortex.com/showthread.php?7471841-Head-Gasket-R-R-and-DIY-3-6L-BLV-2008-Passat
Nater's 3.6 engine saga: https://forums.vwvortex.com/showthread.php?5401088-I-spun-a-bearing-(now-with-pics!)
Technical Guides and Manuals
Timing Chain Alignment Procedure for 2008+ engines only difference for 2006-2007 engines is the hpfp alignment tool.
This website has an excellent reference including special tools required, locations of timing marks, and torque values but it has so many pop ups and other crap I HATE IT
Self Study Program for VR6 FSI Engines 2006-2007
Self Study Program for VR6 FSI Engines 2008 looks the same until page 19
2006 Passat Reference Specification Book (torque specs)
2007-2008 Passat Reference Specification Book (torque specs)
2009-2010 CC Quick Reference Specification Book (torque specs)
2011-2012 CC Quick Reference Specification Book (torque specs)
2007-2010 Touareg Quick Reference Specification Book (torque specs)
How to remove the 2piece intake manifold
How to remove the 1piece intake manifold
How can you tell if you need chains/guides/sprockets
Maybe you have a fuel pump check engine light code, a lot of times people will swap high pressure fuel pump, sensors, fuel pump module when it’s really just a timing wear issue.
So check vagcom measuring blocks 208 & 209. If out more than +/- 8* you need to pull the engine and or transmission and replace the chains & guides and should change sprockets and even the hpfp sprocket (it suffers wear on the lobe
Here is what Ross-tech says to check: http://wiki.ross-tech.com/wiki/index.php/17433/P1025/004133
P1025 - Fuel Pressure Regulation Valve (N276): Mechanical Failure
Possible Symptoms
Malfunction Indicator Light (MIL) ON
High pitched whining noise from engine when idling.
ECM may also have stored in memory, P0088 - Fuel Rail/System Pressure: Too High.
Possible Causes
When found in 2006 to 2009 Volkswagen Passat, Passat CC and Touareg with 3.6L gasoline engines it is possible the HPFP (High Pressure Fuel Pump) / camshafts are out of time.
Possible Solutions
When found in 2006 to 2009 Volkswagen Passat, Passat CC and Touareg with 3.6L gasoline engines:
Check MVB group [208] and [209] with engine idling, if [8 degrees(+/-)] or more the engine is considered out of time.
NAR (North American Region) users can see VW Tech Tip [01-16-05] for exact repair details.
RoW (Rest of World) users may find TPI 2040216/1 helpful.
When found in gas models with a remote battery such as the Q7, P0088 may be stored due to voltage drop issues. TSB 2025746 applies to the NAR market.
https://www.dropbox.com/s/4ijtiag9nktc8vr/MC-10096053-0699.pdf?dl=0
Discussion Starter · #2 · (Edited)
Oil Pump Bolt
Early 3.6L VR6 FSI engines came from the factory with a lower grade oil pump bolt. This bolt could back out, and since the sprocket is driven by the timing chain this could cause the chain to jump time and lead to severe engine damage.
This problem was corrected in the production line for late MY2007 cars and beyond, but if you have a 2006 or 2007 car with a 3.6L VR6 you should assume the bolt is bad and can back out at any time unless you have proof that it has been replaced. Replacement is not difficult but it is labor-intensive due to the bolt’s location. More information can be found:
Oil Pump Bolt Failure Thread.
[URL="https://www.passatworld.com/forums/volkswagen-passat-b6-discussion/327507-3-6-oil-bolt-failure-reference-material.html]Passat World Oil Pump Bolt Failure Thread[/URL]
Proper Oil pump 12.9 bolt part number: Bolt #: N-104-044-04 Its under $2 so just replace it.
Discussion Starter · #3 · (Edited)
Tools
Ross Tech's VAG-Com is my diagnostic tool of choice, I don't know if OBD-eleven can check blocks 208 & 209 for idle stabilization or not. https://store.ross-tech.com/shop/cat/VCDS
T10332 HPFP Sprocket Timing Tool for 2006-2007 engines with the silver intake manifold: https://vw.snapon.com/SpecialToolsDetail.aspx?itemid=34360123
T10363 HPFP Sprocket Timing Tool for 2008+ engines with the Black 2pc intake manifold: https://vw.snapon.com/SpecialToolsDetail.aspx?itemid=22440123
T10068A Cam Locking Bar for 24 Valve VR6 (same tool as used on the R32 and 2.8 24V engines) All 3.6 will need this to lock the cams. Lots of places sell it, I'm a fan of: http://www.metalnerd.com/catalog/product/5378e0ec6f5043dd9d92a4f39e421085
Discussion Starter · #5 · (Edited)
Timing Chain Part Numbers (looked up for a 2006 Passat on 7zap.com verify for your specific engine as they do update parts)
https://volkswagen.7zap.com/en/usa/passat/pa/2006-460/1/109-109090/#23
Lower Chain: 03H-109-465 https://www.fcpeuro.com/products/vw...MIs67x_tyl4gIVxlmGCh3BOgIrEAkYBCABEgLJ3_D_BwE
Lower rail: 021-109-469
Lower tensioner: 021-109-467
Lower Tensioner Bolt-qty 2 (optional): N90923801
Rear Main Seal: 021-103-051-C
Oil pump Large chain sprocket (optional): 03H-109-569
Oil pump Small chain sprocket (optional): 066-109-570
Oil Pump Sprocket Bolt (mandatory) N10404404
These HPFP sprockets get wear on the roller surface. I'd replace anything over 100k miles if I was in a hurry to reassemble and ordering parts before hand.
HPFP Chain Sprocket Early silver intake manifold car: 03H 109 570
HPFP Chain Sprocket Blk 2pc with vacuum pump cars: 03H 109 570 E
Upper chain: 03H-109-503
Upper SLide rail: 03H 109 513 B
Upper slide rail bolt (optional): N10613901
Chain Tensioner Plastic piece: 03H 109 509
Chain Tensioner: 03H 109 507
Chain Tensioner seal: N0138271
Slide Rail (between cams) : 066109514A
Cam Sprocket/phaser Bolt (optional): N91118001
Cam Sprockets/Phasers are specific to year so look those up if you want to replace them. The teeth do wear.
So before I mount my turbo to my cc... I need to replace the chains. I’m about a week away from pulling the engine. Do I need to replace the cam gear? A local VW specialist that I’ve been working with in Seattle told me I need to replace it... it’s a $800 gear. Does it need to be replaced??????
Discussion Starter · #9 ·
All depends, on condition of them.
When I did chains on my 103k mile engine I didn’t replace mine. The wear on my chains and guides was minimal. If you car has bad wear and is at 8* then consider it.
That hpfp gear probably need replacement more than the cam gear. The surface that the roller rides takes a beating.
Have vagcom? What’s the idle stabilization fluctuating around?
No vag com but I have a really nice scanner. The idle stays around high 600- low 700. The HPFP is getting replaced with a different one to be able to handle 650 HP. I’m still waiting on HPA to respond to my email. I just need the chains dealt with first! Lol I’m at 150k miles and I’ve just noticed a little rattle when I’m accelerating in traffic and I hit about 5500-6200 rpm. Doesn’t rattle on startup or when idling. And what do you mean “is at 8*”?
Discussion Starter · #11 ·
If you don’t have vagcom for a VW Audi group car then your scanner is lacking. It’s made specifically for VW Audi Group (VAG) cars.
It provided details that other scanners don’t. It’s what some techs use when there aren’t enough factory scanners available at a dealer.
Now go reread what I posted above about idle stabilization above.
Administrator
Thank you, your threads have been useful to pull info from. I’m just trying to make a one stop shop on 3.6 timing. Sad that forums are dead. I hope they at least live on as encyclopedias for watercooled VW knowledge.
Just had my .:R32 engine built and doing chains on that too. Maybe I’ll make a diy there too.
Administrator
Please do I’m taking my engine out of the car within the next 2 weeks and I’ve personally never worked on a VR just 1.8’s and 2.0’s
You don’t need to wait for my diy. Read all of my threads in here about the 3.6. It’ll give you ALLLL the info you need man.
Many :beer: to you for starting this thread! Hopefully people will keep contributing or at least finding value in this type of thread for many years to come—especially since the 3.6 just won’t seem to go away! :D I’ll add a link to it in my thread. :thumbup:
I can’t seem to find the right ARP head studs for the 3.6... will the R32 ones work or do I need 3.6 specific head studs? If anyone has changed their timing chains themselves can I get a part number PLEASEE!!!!
1 - 20 of 75 Posts
