Ok so I'm not putting together a step by step timing chain job thread because my projects usually don't follow the same steps as people who need to just fix their timing. Also doing the timing on a 3.6 is complicated job that requires you to separate the engine from the transmission. Some people may chose to pull the engine and transmission while others may prefer to just pull the transmission when touareg people might want to pull the engine. Its really a slippery slope and what needs to be done. Most importantly I want people to understand the process of re-timing the engine. where to get parts and the tools necessary.
The beauty of the 3.6 is that it has remained relatively unchanged since being introduced in 2006. I'm running a 2016 touareg engine on 2006 management.
List of vehicles this might pertain to:
Potential USA 3.6 VR6 Donors
Touareg 2007+
Passat 2006+
CC 2009-2017
Porsche Cayenne 2006+
Audi Q7 2007-2010
Atlas 2018+
Information Links
It should be noted that the Facebook page "
VW 2.8 | 2.9 | 3.0 | 3.2 | 3.6 VR6 Performance Group" is useful...sometimes.
Link for looking up VW/Audi Part numbers up:
Volkswagen Parts catalog - ETKA Online, Volkswagen EUROPA, original Catalog Volkswagen EUROPA or
Search for parts. Buying auto parts around the world. Auto parts catalogs.
jddaigle's B6 3.6 & 4motion Resource Thread
Nater's Head Gasket R&R and DIY 3.6L BLV 2008 Passat
Nater's 3.6 engine saga:
3.6L VR6 - I spun a bearing...Plus eventual engine...!)
Technical Guides and Manuals
Timing Chain Alignment Procedure for 2008+ engines only difference for 2006-2007 engines is the hpfp alignment tool.
This website has an excellent reference including special tools required, locations of timing marks, and torque values but it has so many pop ups and other crap I HATE IT
Self Study Program for VR6 FSI Engines 2006-2007
Self Study Program for VR6 FSI Engines 2008 looks the same until page 19
2006 Passat Reference Specification Book (torque specs)
2007-2008 Passat Reference Specification Book (torque specs)
2009-2010 CC Quick Reference Specification Book (torque specs)
2011-2012 CC Quick Reference Specification Book (torque specs)
2007-2010 Touareg Quick Reference Specification Book (torque specs)
How to remove the 2piece intake manifold
How to remove the 1piece intake manifold
How can you tell if you need chains/guides/sprockets
Maybe you have a fuel pump check engine light code, a lot of times people will swap high pressure fuel pump, sensors, fuel pump module when it’s really just a timing wear issue.
So check vagcom measuring blocks 208 & 209. If out more than +/- 8* you need to pull the engine and or transmission and replace the chains & guides and should change sprockets and even the hpfp sprocket (it suffers wear on the lobe
Here is what Ross-tech says to check:
17433/P1025/004133 - Ross-Tech Wiki
P1025 - Fuel Pressure Regulation Valve (N276): Mechanical Failure
Possible Symptoms
Malfunction Indicator Light (MIL) ON
High pitched whining noise from engine when idling.
ECM may also have stored in memory, P0088 - Fuel Rail/System Pressure: Too High.
Possible Causes
When found in 2006 to 2009 Volkswagen Passat, Passat CC and Touareg with 3.6L gasoline engines it is possible the HPFP (High Pressure Fuel Pump) / camshafts are out of time.
Possible Solutions
When found in 2006 to 2009 Volkswagen Passat, Passat CC and Touareg with 3.6L gasoline engines:
Check MVB group [208] and [209] with engine idling, if [8 degrees(+/-)] or more the engine is considered out of time.
NAR (North American Region) users can see VW Tech Tip [01-16-05] for exact repair details.
RoW (Rest of World) users may find TPI 2040216/1 helpful.
When found in gas models with a remote battery such as the Q7, P0088 may be stored due to voltage drop issues. TSB 2025746 applies to the NAR market.
MC-10096053-0699.pdf
