Here is a my new RS4 fuel pump in a mk5 fuel pump housing. I had been using a B6 fuel pump but the United no revhang tune requires the RS4 fuel pump and the RS4 filter and regulator.
When I had a TDI sending unit in my tank I removed the bottom lock ring so that’s why I’m not using a corrado or mk3 fuel pump.
The B6/mk5 design keeps everything in place without a ring in the bottom of the tank.
I’m using the rs4 sending unity because it’s ohms range is about the same as the corrado’s
Corrado’s full is 38.4 and empty is .282
RS4 full is 46.7 and empty is .298
Beats the B6 being reverse and empty being 51.9 and full .289
With the B6 it would start out at empty on the gauge and rise. I never ran empty because I kept track of mileage and would fill up around 200miles but knowing my mpg was 22-28 depending on how I drove it I would sometimes push 300miles on the highway where The gauge would be around 1/3 tank.
It never bothered me but I’m certain some of you OCD people would freak out.
If you can handle that fuel tank gauge topic then I’ll tell you about the tach when I install the converter and cluster later this week. It might set your hair on fire if the gas gauge pings you
Notice the top part of the fuel pump gets ground down so it’s a smaller OD. Also the ID of the locking ring needs to be enlarged to fit the new fuel pumps.
The awd RS4 and B6 fuel pump has an extra line that needs plugging. Here is the plug I made initially for my B6 pump installed on my corrado.
To seal the fuel pump I have used an o-ring for a couple years without issue. Here is the part number,
I think it’s a 4.5” ID
