1 - 6 of 6 Posts
A month ago we started the installation of Swap 3.6 on Jetta VR6 24V 2003
We have a problem with the motor that we cannot solve hopefully you can help me with your experience
We have a low oil pressure problem this causes engine idle failure
We started to check the engine and uncovered finding the lack of the oil check and a problem with the oil pump ... we changed the oil pump, the missing oil check was installed
I share my Full Scan if they have gone through this failure
Wednesday,23,September,2020,20:17:22:08761
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.2.0 HEX-NET CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
VIN: 3VWTH29M2MXXXXXX Mileage: 90740km-56383miles
Address 01: Engine Labels: 03H-906-032-BLV.clb
Part No SW: 03H 997 033 N HW: Hardware No
Component: P3.6-FSI-LEV2 G00 2371
Revision: --H11--- Serial number: XXXXXXXXXXXXXX
Coding: 0000075
Shop #: WSC 03307 993 33075
VCID: 383C02894A71B246EB-5184
2 Faults Found:
000023 - Bank 1: CMP Sensor 3 (G300) / Engine Speed Sens (G28)
P0017 - 002 - Incorrect Correlation
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 1474 /min
Load: 36.1 %
Speed: 0.0 km/h
Temperature: 107.0°C
Temperature: 65.0°C
Absolute Pres.: 770.0 mbar
Voltage: 13.843 V
000406 - Engine Oil Temp. Sensor (G8)
P0196 - 004 - Implausible Signal
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 766 /min
Load: 42.3 %
Speed: 0.0 km/h
Temperature: 101.0°C
Temperature: 63.0°C
Voltage: 13.970 V
Readiness: 0110 0101
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019970
Shop #: WSC 00028 000 00000
VCID: 342436B956195626C7-5184
4 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
00526 - Brake Light Switch (F)
008 - Implausible Signal - Intermittent
00778 - Steering Angle Sensor (G85)
003 - Mechanical Failure
01315 - Transmission Control Module
004 - No Signal/Communication
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 C
Component: CLIMATRONIC C 2.0.0
Coding: 01000
Shop #: WSC 00028
VCID: 210ACFEDA9EBD38E3C-51A8
3 Faults Found:
00792 - A/C Pressure Switch (F129)
35-00 - -
00797 - Sunlight Photo Sensor (G107)
30-00 - Open or Short to Plus
01274 - Air Flow Flap Positioning Motor (V71)
37-00 - Faulty
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 1N AIRBAG VW51 02 0006
Coding: 12622
Shop #: WSC 00066
VCID: 2208C0E1ACEDC89625-513C
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 A
Component: Lenkradelektronik 0004
Coding: 00118
Shop #: WSC 00028
VCID: 2F2E39D5EF3F75FEBA-51F2
No fault code found.
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 826 F
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 07334
Shop #: WSC 00000
VCID: 2C142ED9DE290EE69F-513C
3VWTH29M23M106021 VWZ7Z0B5475273
2 Faults Found:
01177 - Engine Control Unit
64-10 - Not Currently Testable - Intermittent
01304 - Radio
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00028
VCID: 70ACFAA932812A06E3-513C
1 Fault Found:
01304 - Radio
Address 36: Seat Mem. Drvr Labels: 3B1-959-760.lbl
Part No: 3B1 959 760 E
Component: Sitzverstellung 0301
Shop #: WSC 00000 000 00000
VCID: 2F2E39D5BF3F75FEBA-513C
3 Faults Found:
01008 - Note; Emergency OFF Switch is Active!
000 - - - Intermittent
01009 - Sensor for Driver's Seat Position Fore/Aft (G218)
011 - Open Circuit - Intermittent
01173 - Motor for Driver Seat Fore/Aft Adjustment (V28)
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 1H Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 00028
VCID: 373E01B5176FBD3EE2-4B1E
Subsystem 1 - Part No: 1C1959801A
Component: 1H Tõrsteuer.FS KLO 0009
Subsystem 2 - Part No: 1C1959802A
Component: 1H Tõrsteuer.BF KLO 0009
Subsystem 3 - Part No: 1C0959811A
Component: 1H Tõrsteuer.HL KLO 0009
Subsystem 4 - Part No: 1C0959812A
Component: 1H Tõrsteuer.HR KLO 0009
2 Faults Found:
01134 - Alarm Horn (H12)
77-00 - Internal Supply Voltage
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
27-10 - Implausible Signal - Intermittent
End----(Elapsed Time: 05:03, VBatt start/end: 12.1V/12.0V. VIgn 12.0V)-----
What do you mean by "idle failure?"
First code is cam/crank timing is likely off. Second code is for the oil temp sensor on the oilpan. The first code I would be worried about the second you can likely troubleshoot and replace easily.
1 - 6 of 6 Posts
