Quote, originally posted by vag-com » |
Sunday,21,March,2010,12:43:32:50840 VCDS Version: Release 908.1 Address 01: Engine Labels: 03H-906-032-BLV.lbl Control Module Part Number: 03H 906 032 BR HW: 03H 906 032 AB Component and/or Version: P3.6-FSI-LEV2 G 1411 Software Coding: 0000175 Work Shop Code: WSC 05311 000 00000 4 Faults Found: 001072 - Catalyst System; Bank 2: Efficiency Below Threshold P0430 - 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 0 Fault Frequency: 2 Mileage: 139660 km Time Indication: 0 Date: 2010.03.10 Time: 07:50:08 Freeze Frame: RPM: 1967 /min Load: 57.2 % Speed: 97.0 km/h Temperature: 86.0°C Temperature: 33.0°C Absolute Pres.: 1010.0 mbar Voltage: 13.716 V 001089 - EVAP Emission Control Sys: Incorrect Flow P0441 - 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 0 Fault Frequency: 1 Mileage: 141101 km Time Indication: 0 Date: 2010.03.17 Time: 14:58:12 Freeze Frame: RPM: 617 /min Load: 36.8 % Speed: 0.0 km/h Temperature: 84.0°C Temperature: 66.0°C Absolute Pres.: 1010.0 mbar Voltage: 13.081 V 012555 - Low Pressure Fuel regulation: Fuel Pressure Outside Specification P310B - 002 - Lower Limit Exceeded - Intermittent - MIL ON Freeze Frame: Fault Status: 10100010 Fault Priority: 0 Fault Frequency: 3 Mileage: 141308 km Time Indication: 0 Date: 2010.03.18 Time: 15:30:32 Freeze Frame: RPM: 5125 /min Load: 96.0 % Speed: 75.0 km/h Temperature: 84.0°C Temperature: 32.0°C Absolute Pres.: 1000.0 mbar Voltage: 13.208 V 000135 - Fuel Rail/System Pressure: Too Low P0087 - 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 0 Fault Frequency: 1 Mileage: 141778 km Time Indication: 0 Date: 2010.03.21 Time: 12:10:23 Freeze Frame: RPM: 6624 /min Load: 90.2 % Speed: 97.0 km/h Temperature: 90.0°C Temperature: 33.0°C Absolute Pres.: 1000.0 mbar Voltage: 12.700 V Readiness: 0000 0000 |
I'm only really worried about the low pressure codes...
Anybody have experience with this????
The CEL came on (after the code was thrown) after I wailed on it at WOT 1-3 gears. Odd...
