I have had a **** 2 days and i still cant figure out the issue. So yesterday decided to do a trans flush and dog bone inserts. Trans flush went like normal, cars gotta be level so put wood under the rear and jacked up the front (driveway has slight slope). Anyways that's how it was raised. Went to do dog bone inserts. Removal went fine, got the new inserts in, couldn't install it. The engine would not sway far enough forward for the 2 trans bolts to line up. Couldn't figure out why and kept trying to throw my purse at it. Welp, pushed it quick and hard. Heard a metal on metal tap. Well it comes to find out my 3" downpipe/primary o2 sensor was hitting subframe. Decided to undo my downpipe, and was able to get the dog bone in. When reinstalling the downpipe it was full in contact with my subframe, not like tapping it, i mean fully in contact. After messing with it for awhile I decided to put the old rubber back in the dog bone and deal with it another day. Well after removing the dog bone again, taking out the inserts and putting the old rubber in it still had the issue. Downpipe fully in contact with subframe. Tried to install everything fully, in which i ****ed up and stripped my o2 sensor threads. At that point it had been 2-3+ hours so i decided to deal with it the next day (today). When i began today I tried to thread the o2 sensor in my stock downpipe, which luckily, it did without an issue. So now either i need to repair my downpipe or buy another. But I'm still confused on how this happened. How could it be in contact with my subframe? It makes no sense, even if I bent some type of mount by prying I would've bent it the opposite way.
I've tried to think of every possible scenario.
-If I bent something, but I was prying the engine and downpipe away from each other, so if I did bend something the downpipe would've been hitting the top of the tunnel not the subframe.
-If the downpipe wasn't fully seated, but it was. I double checked that it was seated flat.
-The dog bone insert causing it. If it was then why did it still happen with the stock rubber?
I cant wrap my head around this, and the downpipe hasn't been contacting the subframe before as there is no marks on the downpipe indicating so.
Anyone got an idea?
Anyone got an idea?
