Re: 3-spoke steering wheel conversion (Overdrive)
You can get the airbag for around $300 from the dealer. Other than that you just need a socket insert for the 12mm "triple square" nut that holds the wheel onto the steering column. It's a pretty quick swap once you have everything you need.
