1 - 20 of 28 Posts
I purchased this for what I believe is a 2004 Santana for China
Gauge Measuring instrument Gadget Audio equipment Motor vehicle
The plug is a t28 mk3 golf
Rectangle Gas Electric blue Office equipment Engineering
Unfortunately it doesn't work when plug to a mk3 so we need a pinout. I've mapped some so far but I need so help with this.
Handwriting Rectangle Sleeve Font Slope
It's a cool cluster shape is mk1-2 direct bolt in, mk3 plug, mk4 look. I'd love to get this working in my mk1 aeb swap to be different. Any help would be appreciated. Hopefully it's not can bus or its TKO
mk3 golf variant 2.0, passat b1 33 variant tdi project
i've got the same cluster, been searching for the pinout aswell. no luck so far contacting sellers and searching on chinese car forums. from what i've heard the guys that do the color mfd have the pinout but i havent heard from yet.
I can say that it isnt a mk3 pinout, mk4 pinout shoved into a mk3 plug doesnt work either.
Did you get a pigtail with yours? Maybe we can guess with the colors of the wires
i've tried running the santana dash as a slave running jumpers from the santana's gauge steppers to a mk4 golf cluster's steppers but no luck with that either
Discussion Starter · #8 · (Edited)
Update!!!!!?!?!?
Received this from China today
Poussin (07 models) instrument row insert pin definition ffice:
1# Headlight on indicator
2# unknown
3# EPC indicator
4# Water temperature meter indicator
5# Oil gauge indicator light
6# Headlight switch power supply terminal +12V (when the headlight is turned on, this pin is powered on, and the instrument lighting system is powered on)
7# Left flash lamp (left arrow)
8# vss
9# Right flash (right arrow)
10# Battery power supply terminal +12V (used for small odometer and clock power supply)
11# unknown
12# Grounding terminal (grounding)
13# Gasoline indicator light
14# unknown
15# hand brake light neg trigger
16# unknown
17# empty
18# check engine light
19# empty
20# unknown
21# ACC power supply terminal +12V (used to initialize the status of each instrument)
22# empty
23# Rear window defogging indicator
24# Trunk indicator light (negative trigger)
25# unknown
26# battery light
27# empty
28# immobilizer light negative trigger
Will try it out in the next 2 days
This is what I found but I don't think it's useful. This has Can line. No year, no part number.
It doesn't match what they told you from china. I will continue to search
Shurlock Box Pin-Out
T28/1 - Ignition (Brown/Red)
T28/2 - Alternator Sense (Blue)
T28/3 - Coolant Temp Sensor (Yellow/Red)
T28/4 - Engine Speed Sensor Input (Yellow Red)
T28/5 - Hazard Warning Light Switch (White)
T28/6 - Indicator Left (Black/White)
T28/7 - Indicator Right (Black/Yellow)
T28/8 - Heated Rear Window Warning (White)
T28/9 - Hazard Warning Light System Malfunction Lamp (White)
T28/10 - Windscreen Washer Pump (Green/Red)
T28/11 - From Cluster T32/15 (Purple/Black)
T28/12 - Positive + (In dash panel harness)
T28/13 - K-Line (White)
T28/14 - From Cluster T32/24 (White/Black)
T28/15 - Heated Rear Window Switch (Brown/Blue)
T28/16 - Air Recirculating Flap Switch Pin 4 (White)
T28/17 - Air Recirculating Flap Switch Pin 10 (Yellow)
T28/18 - Rear Fresh Air Recirculation Flap (White)
T28/19 - Yellow (Switched Earth in Blower Wiring Harness)
T28/20 - Can-High (Orange/Black)
T28/21 - Can-Low (Orange/Brown)
T28/22 - Intermittent Wiper Switch Pin 5 (Brown/Black)
T28/23 - Fuel Gauge Sender (Purple/Black)
T28/24 -
T28/25 - From Cluster T32/19 (Brown/Blue)
T28/26 - From Cluster T32/26 (Brown/Green)
T28/27 - Rear Wiper Switch (Green Red)
T28/28 - Rear Window Wiper Motor (Green/Red)
T12/1 - Positive + (Black/White)
T12/2 - Positive + (Black/Yellow)
T12/3 - Heated Rear Window (White)
T12/4 - Windscreen Wiper Motor (Green)
T12/5 - Intermittent Wiper Switch Pin 3 (Green/Black)
T12/6 - Positive + (Windscreen Wiper Harness) (Black)
T12/7 - To Fuse Holder Positive 15A (Black/Yellow)
T12/8 - To Fuse Holder Positive + (Red/Green)
T12/9 - Positive (Red)
T12/10 - Ground (Brown)
T12/11 - Positive + (Black)
T12/12 - Positive + (Black Yellow)
Citi Golf Cluster Pinout
T32 (Green)
T32/1 - Not Used
T32/2 - Headlights on Signal (White)
T32/3 - Not Used
T32/4 - Not Used
T32/5 - Not Used
T32/6 - Speedo Sender (Blue/White)
T32/7 - Can-Low (Orange/Brown)
T32/8 - Can-High (Orange/Black)
T32/9 - Not Used
T32/10 - Not Used
T32/11 - Not Used
T32/12 - Not Used
T32/13 - Not Used
T32/14 - Not Used
T32/15 - Fuel Gauge Input (Purple/Black)
T32/16 - Bridge to T32/32 (White)
T32/17 - Not Used
T32/18 - Choke Switch (Black/Yellow)
T32/19 - Alarm LED (Brown/Blue)
T32/20 - Not Used
T32/21 - Hand Brake Switch (Grey/Green)
T32/22 - Brake Fluid Level Switch (Blue/Brown)
T32/23 - Oil Pressure Switch (Blue/Black)
T32/24 - Can-Wake Up (White/Black)
T32/25 - Not Used
T32/26 - Can-Ground (Brown/Green)
T32/27 - Not Used
T32/28 - Not Used
T32/29 - Not Used
T32/30 - Not Used
T32/31 - Not Used
T32/32 - Not Used
T8 (Black)
T8/1 - Not Used
T8/2 - Not Used
T8/3 - Not Used
T8/4 - To Headlight Switch / Park Lights R (Green/Red)
T8/5 - Ignition Supply from Fuse
T8/6 - To Headlight Switch / Park Lights L (Green/Red)
T8/7 - Postive from Fuse (Red)
T8/8 - Ground (Brown)
Discussion Starter · #14 ·
T28/24 -
T32 (Green)
T32/1 - Not Used
T32/3 - Not Used
T32/4 - Not Used
T32/5 - Not Used
T32/9 - Not Used
T32/10 - Not Used
T32/11 - Not Used
T32/12 - Not Used
T32/13 - Not Used
T32/14 - Not Used
T32/17 - Not Used
T32/20 - Not Used
T32/25 - Not Used
T32/27 - Not Used
T32/28 - Not Used
T32/29 - Not Used
T32/30 - Not Used
T32/31 - Not Used
T32/32 - Not Used
T8 (Black)
T8/1 - Not Used
T8/2 - Not Used
T8/3 - Not Used
thats the south africa mk1 citi goff . no good for this aplication
Discussion Starter · #17 ·
No I've been busy but where I'm at is:
I need 3 more pins out of 7 unknown
Vss Input
Tachometer input
Fuel gauge
So I can trial and error in the least dangerous way as it the tack wire first then the vss then fuel . That's where I'm at . I don't have an oscilloscope so if anyone has ideas let me know.
Vss Input
Tachometer input
Fuel gauge
Any luck?
Trimis de pe al meu GM1913 folosind Tapatalk
1 - 20 of 28 Posts
