Hello,Do you still have a pin out for this kilometer clock from chine?
Can you send me to the e-mail:
[email protected]
Thank you!
This is what i have so far. for anybody outhere working on this PLEASE post what you find. we still need vss, rpm fuel guage. whatever else is left technicly is not needed
Poussin (07 models) instrument row insert pin definition ffice:
1# Headlight on indicator
2# unknown
3# EPC indicator
4# Water temperature meter indicator
5# Oil gauge indicator light
6# Headlight switch power supply terminal +12V (when the headlight is turned on, this pin is powered on, and the instrument lighting system is powered on)
7# Left flash lamp (left arrow)
8# vss
9# Right flash (right arrow)
10# Battery power supply terminal +12V (used for small odometer and clock power supply)
11# unknown
12# Grounding terminal (grounding)
13# Gasoline indicator light
14# unknown
15# hand brake light neg trigger
16# unknown
17# empty
18# check engine light
19# empty
20# unknown
21# ACC power supply terminal +12V (used to initialize the status of each instrument)
22# empty
23# Rear window defogging indicator
24# Trunk indicator light (negative trigger)
25# unknown
26# battery light
27# empty
28# immobilizer light negative trigger
