1999 Golf GTI 2.slow, 2000 Beetle GLS 2.slower, 2001 Golf GTI 1.8t
Its the hatch emblem from the back of the car. You can nab them from the junkyard or purchase aftermarket ones from eBay or AliExpress for like $10. They come with precut adhesive, so you just stick it on the 3D printed clip.
On higher trim cars like on the Passat and Audi's, there's a little vent inside the glovebox. Apparently it's to keep a bottle or unopened soda can cold for longer by turning the glovebox into a mini cooler using the AC.
If you look at the back of a Golf/Jetta glovebox, there's a little template punch out for it. The valve from the Passat will fit, but the mounting tabs for the air hose are missing on the Golf/Jetta HVAC box (see the image below for a Passat HVAC box). The 3D printed adapter does away with the mounting tab and runs the hose directly to the glovebox.
I'll write actual installation post after I get to it.
