Re: 40k service (GAhamby)
Did you get this Passat through a Private Party, a VW Dealer...????
40K is a major Service for VW: Oil & Filter replace, replace Spark Plugs,
Check condition of timing belt,washerfluid checklevel, Autoshift Lock check,Check brakes, Rotate wheels, front to rear, battery- check electrolyte
level,replace dust/pollen filter, Manual/ Tiptronic Trans. check for leaks, check
tires & spare, drive shafts- check boots, OBD check DTC memory, door check straps- lube, Roadtest, Replace Air Filter, Cooling System -check level, V Belt
check condition, Ribbed belt- check condition, front axle check, check ATF &
differential level, adjust headlights, check AirBag system...
[Modified by vwguild, 5:06 PM 11-23-2001]
