1 - 2 of 2 Posts
Question.i was running a 42dd turbo back on my old gti
Wondering if can use the same turbo back 2.5 with. Diferent size 3 in muffler same brand ?? I will need some adapters or ???
Sent from my LGMP260 using Tapatalk
You will need 2.5” to 3” adapter and 1- 2.5” and 1-3” exhaust clamp of the same material as the exhaust example Stainless Steel , Aluminized steel, Galvanized etc…
2003 VW New Beetle GLX 1.8T,06A AWP Block,AEB head, Crower Stage 3 Cams,Big Turbo GTX3582 .70/.82 A/R, Turbosmart 38mm EWG, Siemens 1000cc/Gen.2, HKS SSQV BOV, Winols ME 7.5, Mafless,SAI,EVAP, rear 02 Delete, IMMO DEF, E85-E100 tune, Greddy FMIC, 30row -10AN oil cooler, HellCat 550lph pump. 5bar aFPR, bored/honed/stock 03+ small port intake manifold, 3”I.d. DP/Turbo back/ hood exit/ 3”I.d stock placed exhaust w/cutout-electronic. Stage “4 extreme,daily” SBC clutch kit. 04 VW GLI K04-064 ,AEB TT225 head ,AWP block , maestro me7 LowLyme martytuned 2++ full delete/defeat tune, 3” cat delete exhaust straight piped. Stage3 clutch. 03 VW Wolfsburg 1.8t Jetta K04 built head stage 2 clutch stage 2 tune. Stock bottom end, stock injectors. All solid builds. Only one is a BEASTLE.
1 - 2 of 2 Posts
