Re: 4Motion = Quattro ? (redlands_gti)
quote:[HR][/HR]to restate and elaborate on what i had previously stated
4-motion is front wheel drive all of the time until the abs sensors (that computers that i had stated eariler) detect wheel spin. They detect it in like 1/1000 of a second, then the computer adjusts and puts the power to the other wheels.
Quattro is always putting power to all of the wheels through the Torsion differentials via worm gears. COMPLETELY mechanical. Always changing, always giving the wheels with the most traction the most power.
Hope this clears it up.[HR][/HR]
Again, this is not entirely true. Please re-read the posts from above. 4-Motion and Quattro are just VW's and Audi's branding name ONLY. You can have an Audi car using the Haldex system (the so-called FWD system you described above)... for example... the Audi TT uses Haldex, as well as Golfs and Jettas.
The Passat V6 and W8 has the Torsen system, just like most Audi's, which have the so-called permanent mechanical system you described too.
Please, once and for all, 4-Motion and Quattro are
ONLY branding names, not a system!!!!!
