1 - 4 of 4 Posts
Okay, I got the back two mounts set in perfect places, but now the front.. I removed all the stock seatmelt mounts, i wanted to mount them there. But my O-bolts can't just go onto the piece that slides into the track because... Well because you can't have a bolt inside the track. I am thinking of having te brackets that the stock seatbelt things were on cut down, then having a hole drilled in them so I can put the O-bolts in.. What has everyone else done?
Re: 4pt Harness monting help (gliplow)
Mine fit in perfect. I removed the entire seatbelt assembly on the seat. now all i have is the harness. take pics if you can, and i will try and walk you through it
-Greg
my schroths fit right over the eye bolts already in place, however, i got new sets of bolts with the kit. does ur come with new bolts or no? what kinda of harness did ya get?
-Greg
1 - 4 of 4 Posts
