1 - 5 of 5 Posts
5 vacuum at idle, 12 psi at wot...
-checked ECU->TB hose, no visible cracks but im going to replace it.
-checked intercooler tubes, tightened screws
-checked boost guage tubes, no visible leaks,kinks,cracks.
need to check:
-cam timing
-silencer box
-isv
-apex strips???
any tips and info on where i should begin first etc, would be greatly appreciated. thx
Re: 5 vacuum at idle, 12 psi at wot... (TBT-PassatG60)
Quote, originally posted by TBT-PassatG60 »
k, the problem doesn't sound charger related, as your vacuum readings aren't correct.
check CO pot for leaks
check all vacuum lines
check the boost tube under the battery, as they are leak prone.
i am unfamiliar with the boost tube UNDER the battery?
would it be in the same location because of my swap?
ty
Re: 5 vacuum at idle, 12 psi at wot... (andrew1984)
5 vacuum at idle
^^ severely retarded distributor timing (double check it) or you cam belt is off .
or you got a bumpstick better than the rest of us
1 - 5 of 5 Posts
