Re: 5th injector problem (Questor)
the wirign diagram shows the circuit path to go from starter, to tts, to csv. the starter power being from a relay inside the starter that is activated when the starter is cranking. thus the csv sprays constantly with the starter, until it's cranked for long enough that the TTS has heated up and broken the current path.
in my diagram (85-87 canadian cis), it shows another connector "t2a" that i cannot locate anywhere, nor can i locate where this connection goes to, as i can't find a matching set in any wirign diagrams.
does anybody know if there is a "pulsing relay" anywhere in an early CIS A2s, and where it is? vdubs found a mention of it in a mitchel manual, and we have found "cold start relay" mentioned on some obscure parts sites, it should be a 3 prong unit, like a flasher module. supposedly it becomes the current path for the CSV, after the car has started, for a few seconds.
