Im involved in that whole Eclipse sub mess over in the audio classifieds. I bought the speaker thinking it was a 4ohm sub. Now I found out its 6 ohm. Does anyone even make a 6 ohm amp. How do I go about powering a 6 ohm sub? Am I looking at buying another speaker or two inorder to get this to work?
So lets just say for now that I buy a second sub. Can I wire it so its than a 3 ohm load. The sub has a continuous power handling of 500W at 4ohms. What type of amp would I be looking at to power 2 subs at 3 ohms?
quote:[HR][/HR]So lets just say for now that I buy a second sub. Can I wire it so its than a 3 ohm load. The sub has a continuous power handling of 500W at 4ohms. What type of amp would I be looking at to power 2 subs at 3 ohms?
[Modified by FlashRedSLC, 8:16 AM 8-9-2002][HR][/HR]
dood.. these are your options.. they are DVC aren't they? I am pretty sure they are since I have only worked with the newer models out.. (I currently own them) the setup I am showing is for a MONO load only.. so go find yourself a decent 2ohm stable amp.. with decent amount of power.. and you should be alright..
1 sub: series-parallel will yield 12 ohms
parallel will yield a 3ohm load
2 sub: series-parallel will yield a 6ohm load
parallel will yield a 1.5ohm load
3 sub: series-parallel will yield a 4ohm load
parallel will yield a 1ohm load
Okay this may sound really too simple, but why not just power your 6 ohm sub with whatever ya got?!
Seriously. Six ohms is not far enough away from 8 to make a diff to an amp that can't do 4 or 2 ohms... and of course, if your amp already is stable at 4 or two ohms, you can drive the 6 ohm speaker with it and not have any problems.
The rule is that you can always drive a higher impedance than your amp is rated for, but if you go too much lower, you risk frying something.
Hmm let me qualify that... the above rule applies only to solid state amps... tube amps are different in this regard, but who runs tubes in their auto?
Just hook it up. It'll work peachy. Honest
quote:[HR][/HR]Okay this may sound really too simple, but why not just power your 6 ohm sub with whatever ya got?!
[HR][/HR]
true. you won't get anymore power or anything, and quality won't be that of a 6ohm load, but it will work fine without any risks.
yor amp should be fine with a 6ohm sub. if it is a quality amp, then wire it to 3ohms (if it is a dvc). put a jl 500/1 on that bad boy!
and FYI==> http://www.eclipse-car.com is actually written by one of eclipse top R&D Engineers. they are proud of his site and tell retail employees to visit for any rel questions they have. it is very informative.
true. you won't get anymore power or anything, and quality won't be that of a 6ohm load, but it will work fine without any risks.[HR][/HR]
The impedane rating of the speaker versus that of the amp has not one thing to do with the quality of the sound that will be reproduced by either or both. Why would it?
I don't pretend to know what the impedance of the amps are that everyone is using, but let me assure you that the amp you are using (doesn't matter what it is) does NOT have the same output impedance as the speakers you are connecting to them.
If the amps had the exact impedance of the speakers they drive, literally half of the power the amp is supposedly producing would be lost in the output stage, when really what you want is for the speakers to be getting all that power!
In short, buy good stuff (amps and speakers) and hook them together and enjoy. Life is too short for complications
well, you are mostly right, but yes, it can affect the sound quality. Impedience is resistance. If you put more resistance on the amp then it was meant to see, then you will reduce the output of the sub. The power will be lost to resistance. (unless your amp has a regulated power supply like a JL amp...thats a different story). If i put an 8 ohm speaker on a Rockford bd1000, then the sub will be MUCH quieter than the guy who was smart enough to put his 2 ohm speaker on the amp, like it was designed to see. No, the 8 ohm sub probably will not sound like poop (as in blown or static-y), but it will be MUCh quieter. Some amps actaully do not like to see higher resistance than what they are designed to see.
sean
for anyone watching trying to find out whats going on here..
Picture resistance in sub like a water tube.. amp is pump.. Imagine if you had a tube too big for pump and the pump was made so it would run away and blow up.. Thats what your amp will do with too low of a impedance (ohm load) sub. Don't try to run a common amp below 2 ohms.. Now say 2ohms would be like a 1" hose.. and 1ohm would be like 2 " hose the 2 inch hose will make the amp(pump) blow.. Then a 4 ohm sub woud be like a 1/2" hose and a 8ohm sub would be a 1/4" hose.. Now the 1/4" hose aint gonna flow any water volume at all compared to what the 1" hose can do.. They idea for a bass amp is get to maximum power output..
While your 6ohm sub will work fine off bridged amp your not gonna get full benifit out of selected components unless you drop that load.
Related Threads
Ask a question
Ask a question
VW Vortex - Volkswagen Forum
84.4M posts
1.5M members
Since 2001
