1 - 20 of 22 Posts
Heres the situation, Im having my g60 swapped into my A1, Ps and AC removed, stg 3 kit, unorthodox crank pulley, 260 cam and adj cam gear etc. The car is not a daily driver and the charger has recently been rebuilt. The engine has 226,xxxkm's on it , anyone have any advice on which pulley to use 68 or 65mm or other?
Re: 68 or 65mm pulley? (Reaper)
68mm pulley on the charger, in theory, will last longer, but if you want the power, and can afford a rebuild every 50k miles, go with the 65. MORE POWER!!!!!!!!!!!!!!!
that unorthodox crank pulley is probaly an under drive pulley and will spin the supercharger and alternater slower, less boost and less voltage.
Discussion Starter · #6 ·
Re: (deth_core)
No, Im just going for a mild stage 3 and cam. Cant afford the head work right now.
Crank pulley(so I was told) I bought off someone selling on here, said it was same size but lighter. Wouldnt that make it spin faster not slower?
Re: (LagunaSecaBlueMK3)
Quote, originally posted by LagunaSecaBlueMK3 »
get as much power as you can, i say 65mm, maybe 62 if you dont mind the added cost of a once over every several months
if he wants more power, then he'd go stage 4... don't you think? i recommend porting before you throw a tiny ass pulley on the charger.
...my 2 cents anyway...
Re: (deth_core)
now now tiny ass pulleys are fun too
once you go 62 you'll never go back, unless someone borrows your car and puts a 68 back on it lol..
Moderator
Quote, originally posted by Reaper »
65. Just do it. You know you want to.
Discussion Starter · #13 ·
Re: 68 or 65mm pulley? (robbyb413)
Okay I guess I'll go with the 65 if you really want me too
deth_core you really had me going for the 68 but popular opinion has made my decision. You can be the 1st one to say I told you so when Im pissed about the engine needing a rebuild shortly
Modified by Reaper at 10:27 PM 5-20-2004
Discussion Starter · #14 ·
One more question, does the 65mm take the same belt as the 68mm with A/C delete? thanks
yeah i dont think you can get a smaller belt in that increment. Iirc i was running the 62mm with the 68 belt without problems.
go for it dude....
they're right, you'll probably end up putting on 65 eventually anyway.
my g-lader is in pieces, i blame tiny ass pulleys.
Re: 68 or 65mm pulley? (88mk2g60)
I have a 65mm and I don't go past 6000 rpms and going that high only happens every so often. I believe you're safe up to 6200 rpms w/ a 65mm.
Brian
Re: 68 or 65mm pulley? (ButchHusky)
Quote, originally posted by ButchHusky »
Brian
Any input on this oliver?sam?dave?
1 - 20 of 22 Posts
