FAQ
To have anything added to this list, use the report post to moderator function
When you are searching for an answer to a question, use the Fourtitude search function. if you cannot find the answer to you question in the Recent Topics try changing the Data Set to Archived Topics and you might find an answer
80/90/Cq FAQ
FAQ: Buyrs Guide & Common Problems
1.8T Engine Swap
Rear Vented Rotor Combinations for the Coupe
Porsche 996 brakes on a 90 coupe
Rear Sway Bar for Coupe, 80/90, 4000, Ur-quattro
7A Injector Woe's? The Solution....
Stainless exhaust system buildup
DIY: 20V Timing Belt Change
Rigid bumper repair D.I.Y.
interior leaks f.a.q
tt pedals on a 90 D.I.Y
4X108 to 5X112 hub swap
Modified by StormChaser at 7:33 PM 4-17-2008
Modified by StormChaser at 7:52 AM 8/31/2008
Modified by StormChaser at 6:47 PM 1-2-2010
Modified by StormChaser at 6:48 PM 1-2-2010
80/90/Cq FAQ
1.8T Engine Swap
