Have an 80 pickup I recently did an engine//trans swap into. Has the 1.6D NA. Pretty sure the engine is actually an early Mk2 since it's a hydraulic head but my Q should be rather universal.
Timing is set to 1mm...pump is off the shelf used from the parts bin but the timing plunger is free but a recent test drive has me questioning the vane pump health. Truck has a 2-tank conversion...tank currently has only 4-5gal of straight diesel & a lift pump...this helped as before I couldn't get above 50mph before I could feel it losing power.
Pump timing is set right @ 1mm. On test drive that got up to ~65mph my temp climbed to ~220+ on the open flat. This is not in keeping with the previous motor's (early 11mm head) behavior...which still ran but was a bit gutless even for these already gutless motors...just needed a head gasket but the trans had stuck in 5th. Could 1mm timing be too much?
Also my parts bin includes 8-9 other IPs. A couple were already in pieces so was able to get a feel for how they go together while video's filled in the small bits not known. Pretty simple. My other Questions are what the (dis)advantage of the different shims between plunger head & cam plate? As I do have some variety here. Also when piecing the disassembled heads back together I discovered I have at least a couple different sized plungers//heads as one would fit one but wouldn't even start in the other. Benefits of the smaller compared to larger?
I realize some of these IPs could likely do w/ proper rebuilds to replace parts worn way out of spec. I do have dial gauges (would just need to set up jigs) and a mics (though SAE on the latter). But cleaning & basic reseal works too.
I'm after economy primarily & at least reasonable power.
