Next up is taking a step at addressing my small fuel leak. Basically, I have a stronger than normal fuel odor coming from my passenger rear area. From underneath the car, it's clear there's a moist area at the passenger side of the fuel tank and its origin somewhere above that. I'm also noticing that the connection between the flexible hose return line and tank is moist...so I'm hoping it has something to do with this hose and not the tank. This may be wishful thinking.
My plan is to run the tank near empty, jack the rear passenger corner, remove the fuel pump & cradle, gain access to this flexible hose return line and replace it. I'm hoping with the tank near empty and the rear passenger corner raised, there will be minimal fuel running out of the return line and pump supply point...tbd. I've got some plugs that will be introduced regardless.
Since I'm removing the fuel pump, I've ordered a spare as well as replacement crush washers, supply hose and associated clamps. Regarding the fuel pump, I ordered one from autohausaz. It's listed as a Bosch (OEM) but is considerably cheaper than the Bosch noted under mk1autohaus (not in stock) and partsplaceinc (in stock). Am I missing something?
First photo shows moist area on passenger side of tank near fuel pump.
Second photo hints that the fuel leak may be originating higher up and there's an arrow pointing to flexible hose return line (dry end).
Third photo highlights the ends of the flexible hose return line (tank end shows moisture).
