This is a continuation of a previous build moving in to a new car. My 83 had bent frame rails and was never a solid start. There should be some quick progression in this thread since I will just be swapping my nearly finished project from the 83 to the 84. The 84 is overall clean but needed some repairs to the lower half of the core support. The 84 is being repaired and will start to get a slew of parts transferring from the 83 upon completion of the core support repairs.
Specs are as follows:
Engine:
OBD2 ABA bored .050
Wossner forged 12.3:1 high compression pistons
SCCH knife edged crank shaft
SSCH lightened intermediate shaft
ARP headstuds
Techtonics Tuning HD valve springs
Techtonics Tuning chromoly retainers
Techtonics Tuning adjustable cam gear
Techtonics Tuning lightweight intermediate shaft gear
Port and polished OBD2 head converted to solid lifters and clearanced for oversized cam
+2mm Supertech stainless intake valves
+1mm Supertech stainless exhaust valves
Kent Cam Race 300* race cam
Racelang 4-2-1 stainless header
Techtonics Tuning 2.25 stainless catless exhaust with magnaflow muffler, using v-band clamps
Megasquirt v2 engine management
Nubwerks ABA intake flange with custom runners to fit Mikuni 43mm throttle bodies from GSXR750
1.8t 31# injectors
16v windage tray
Mocal 19 row oil cooler and sandwich plate with Goodyear -8 hose and Integrated Engineering -8 black fittings
Transmission:
CRU coded O2A from passat 16v
OE flywheel lightened to 14 lbs
Sachs VR6 clutch disk and pressure plate
O2A mounts to fit MK1
Pedal clutster and brake master cylinder brackets built to house hydraulic conversion
Suspension:
SCCH 2" spherical drop pin kit
Prothane polyurethane bushings
EuroSport camber plates
Brakes:
Corrado Girling 60 calipers and 11" front rotors
mk2 rear disk conversion
Stoptech braided steel brake lines
Mintex red brake pads
Wheels and Tires:
949 Racing 6UL 15x8 +36 offset 11.6 lbs per wheel
205/50/15 Toyo RA1
Safety:
4 point welded DOM .090 roll bar and rear strut brace
MOMO fiberglass bucket seat
Stroud 5 point seatbelt
MOMO wheel, NRG quick release hub
MK1 steering column lowered 1.5"
Electrical:
EZ Wiring 18 circuit mini kit
Painless Performance rocker switches
MK1 oil temp, oil pressure, volt meter gauges
Porsche 944 8k tachometer
Innovate motorsports LM1 AFR gauge
Some previous and current progression photos:
Day I brought the 84 home
Pulling the JH and trans out
Core support damage
New core support from the junk yard (yes I am staying square)
Old core support removed
To conclude this first post I am ready to fit the new core support to the 84. That should happen this weekend. I will be pulling everything from the 84 and putting it in the 83 to sell as a complete car. wiring interior engine trans etc... until next time...
eace:
Engine:
OBD2 ABA bored .050
ARP headstuds
1.8t 31# injectors
16v windage tray
Transmission:
Suspension:
Brakes:
Wheels and Tires:
205/50/15 Toyo RA1
Safety:
Electrical:
Core support damage
