1 - 2 of 2 Posts
I need to know what an 8v should be timed to, im doing a tune on a friends car.
also if the timeing is advanced on the 8v will there be any horse power gains ? also has anyone done it before , is there any danger in tuinging it forward thanks .
Re: 87 , 8v timeing (Tacowolf)
CIS? CIS-E?
probably 6degrees BTDC. There should be a mark on the flywheel if you pull that green plug thing out of the tranny bellhousing. timing light off cyl1. The flywheel comes with a TDC mark, or a mark at the actual timing mark.
1 - 2 of 2 Posts
