1 - 2 of 2 Posts
I have too many questions
I saw Futrell sells euro-bulb holder conversion kit.
Mine is 89 GTI 16V, which dont have bulb holder.
I want to change my broken tail lamp assembly but
only euro(bulb holder necessary) tail lamps are seen.
If I can get the bulb holders from junkyard, can I
do the conversion, without the kit?
(I mean... I have no wiring diagram... no connector
as seen in Futrell's kit..)
Hope this topic is not beaten to death...
Re: 89 GTI tail lamp to Euro bulb holder conversion (NuWorks)
Yes you can do it once you have the bulb holders and the Euro lights. I used a Jetta tail light wiring harness which plugs straight in. But the pins need to be re-arranged for a golf tail light and wires soldered to the original harness. Or you can use regular wires and connectors, it will work just fine. The wiring is pretty simple, brake/tail/signal/reverse/fog and one ground for both sides.
[Modified by vwtoys, 8:41 AM 2-7-2003]
1 - 2 of 2 Posts
